Old 02-02-2009, 04:25 PM   #1
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
s14 front hub
I am going to be ordering the flca ball joints and I did some research and found out in order to use the s14 front spindle you also need s14 flca ball joints i want to be sure this is true and if it is what ball joints are durable enough to take some abuse?
redline racer510 is offline   Reply With Quote
Old 02-02-2009, 06:42 PM   #2
orion::S14
orion::S14's Avatar
Moog.
And yes, if you're converting to S14 spindles and hubs (5-lug)...you'll need S14 ball joints. They will press right into your S13 LCA's.
- Brian
www.KA24DEvelopment.com
