Old 02-12-2009, 11:17 PM   #1
H4ck3d4l1f3
H4ck3d4l1f3 is an unknown quantity at this point
Studdering?
I tried posting this up on NWN but it seems like no one had any idea at all. It seems like its going down the hole over there as far as people with knowledge goes. I have hope Zilvia!
So to start off with I have a relatively stock S13, Redtop sr20. Fmic, exhaust..
When I'm driving normally everything seems to be fine, nothing out of the ordinary and when I'm in neutral and rev it nothing happens, but when i get on it weird shit starts happening. First off it makes this horrible noise, I can mainly hear it out of my exhaust if that makes sense. It's sort of a BAAAAAHHH!! noise. Basically just sounds pretty loud and awful, kind of like a studder? Also at that time it will pretty much cease to accelerate any further
The weird thing is it doens't happen all the time... Maybe a few times a day, some days not at all. But when it does, it's hard to make it stop.
I've heard that it might be a collapsed boost line or somthing, im not sure exactly what he was saying.
Finally, I've tried searching with no prevail. Any help would be great, thanks.
H4ck3d4l1f3 is offline   Reply With Quote
Old 02-12-2009, 11:34 PM   #2
ChicagoS14
ChicagoS14's Avatar
ChicagoS14 is making a name for him/her selfChicagoS14 is making a name for him/her self
Send a message via AIM to ChicagoS14
Are you hitting fuel cut? Bad timing? Do you have an aftermarket blow of valve? whats your boost setting? what kind of injectors do you have, any fuel management?
95 240SX 1JZGTE | SC300 2JZGE daily
www.240sxguide.com
ChicagoS14 is offline   Reply With Quote
Old 02-12-2009, 11:41 PM   #3
H4ck3d4l1f3
No fuel management, stock boost although it does like to spike a little bit now and then, Greddy RS bov, i don't think it's fuel cut because it's never happened before and it's not even that high of rpm, and i don't know about my timing.
I've had my motor in for about 6-8 months and it just started doing this. Again, it probably happens on average about every other day, seems to go away after i park and my car sits for a few hours.
Old 02-13-2009, 12:09 AM   #4
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
You can try running some fuel injector cleaner, your injectors might be a little bit clogged. Sounds to me like it might help. Does the sound sort of portray the sound a subaru makes? (Might sound like it's running on 3 cylinders)?
DataXUnknown is offline   Reply With Quote
Old 02-13-2009, 12:16 AM   #5
H4ck3d4l1f3
Yeah i was kinda thinking it might have been missing or something? The injector thing sounds totally plausible. One time it was really bad and at idle every 10 seconds ish or so there would be a reallly low quite thud and my rpm would drop a hundred or so and then go back up to normall.
Old 02-13-2009, 12:21 AM   #6
SlideWell
SlideWell's Avatar
SlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfection
youve got a pretty decent shop near you, UnNatural. Chris does great tuning work for them. he tunes all the Position 1 cars there. but taking that your from NWN, im feelin that ur not lookin to pay someone to make your car right the way it should...
oh, and my input on this thread is MAF
SlideWell is offline   Reply With Quote
Old 02-13-2009, 08:23 AM   #7
H4ck3d4l1f3
I don't really see how that's relevant to my question.
Old 02-13-2009, 10:53 AM   #8
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
check timing, fuel pressure (pump might be going), look at your plugs, check your coils
No... no one stole my interior... its safely in my garage...
xsparc is offline   Reply With Quote
Old 02-14-2009, 11:47 AM   #9
H4ck3d4l1f3
half a can of seafoam in my gas tank problem solved!
