Old 02-13-2009, 11:28 AM   #1
s13pignose
s13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of light
IS this the KA coolant temp sensor for ECU
http://www.thenismoshop.com/ikorb.ph...oduct_id=13030
to my understanding there is 2 sensors for coolant temp. one for gauge and one for ecu. I want to make sure I get the one for ecu, as I'm guessing it's the only one that makes a difference in engine performance?
Also is it the same sensor for ka24de and ka24e? They don't have two versions, just says all ka's
thanks
s13pignose is offline   Reply With Quote
Old 02-13-2009, 11:32 AM   #2
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Your link sends me to the main nismo shop page, not to any specific product page. The coolant sensor for the computer is a screw in sensor and has a red 2-pin connector. If you change the sensor it would be wise to change the connector as well though. The majority of coolant sensor problems are actually due to corroded connections rather then bad sensors. You can buy the connectors separately, just don't butt connect it when you splice the new pigtail in. Solder and shrink wrap it.
EDIT: I guess you fixed the link before I was even done typing. Other then the connector color it looks to be correct. Why don't you trust them? I mean it's not like you are ordering it from vatozone or something.
Old 02-13-2009, 11:52 AM   #3
ixfxi
Guest
Posts: n/a
ECU sensor is multi-wire
gauge sensors are 1-wire
so short answer is YES, thats it.
hahgah vatozone.. funny aron.
Old 02-13-2009, 12:08 PM   #4
projectRDM
projectRDM's Avatar
For the KA, the 96-98 uses a different sender with a snap in plug, versus the clip style plug found on 91-95s. The early ones have a red end, later ones are blue.
FORMERLY R240NA
Old 02-13-2009, 12:44 PM   #5
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
i wanna be the 3rd person to say YES thats the right one
No... no one stole my interior... its safely in my garage...
xsparc is offline   Reply With Quote
Old 02-14-2009, 12:27 AM   #6
s13pignose
I don't know what happens, but whenever I try to login on zilvia it acts really weird. I can login, it'll accept it, but then make my login again??? Also I couldn't perform search function because of a "invalid security token". Also I was aware my link was the homepage after I tried click it after posting it. I also corrected it by putting in the direct link. Well I end up going through user statistics to find this thread which was my only way since I wasn't allowed to search, and then I noticed it never showed the direct link I posted after the mainpage one??? Then when I finally do get to login and stay login, it shows the direct link. Might have to notify a Mod.
So yea I wasn't trying to put you guys through hell trying to find the page for coolant sensors on west covina's site lol.
thanks
Old 02-14-2009, 12:32 AM   #7
s13pignose
It's just they through me off when they said all ka's, but yet they have specific sensors for the sr's even though they're all sr's.
See I have 95, projectRDM said they use different connections. So unless they ask for my year car, how are they to know. I don't wanna end up with wrong part lol
Old 02-14-2009, 10:46 AM   #8
projectRDM
projectRDM's Avatar
The 1995 sender is the same as the S13, so you're fine, which is the one shown in the picture (although it's the wrong color, but that doesn't matter). The plug is all you're worried about. Order it.
FORMERLY R240NA
Old 02-14-2009, 11:18 AM   #9
s13pignose
Ok thanks man
Old 02-14-2009, 04:21 PM   #10
neverrain
neverrain's Avatar
neverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud of
I lol'd too.
neverrain is offline   Reply With Quote
