![]() Join Date: Apr 2007
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Studdering problem.PLEASE HELP!
OK so i have had this problem for along while and im just sick and tired of it. I have an s13 sr20det, the problem is that when start the car its idles fine at about 1k but it sounds like its a wrx (studdering) it sounds like this when i drive too, all the time.
I did a test to see if it was my injectors one by one and taking notice of any changes in idle. Cylinder one had no change. so i replaced it ...same problem. i have also changed the plugs, fuel filter (z32), checked grounds, vac, and boost leaks. I dont loose boost but or idle low, jus this stupid studdering sound. Some times i get a more lean than normal afr reading from wideband also. any ideas?
www.teamirrational.wordpress.com |
Try swapping the coil of the one that made no difference to another and then unplug the injectors to see if there is a change. A change is a good thing as you will know it is a bad coil.
i got this same suggestion from my brother..ill try it the morning
