Old 02-14-2009, 06:41 PM   #1
krislin
krislin is an unknown quantity at this point
SR Electrical/Idle issues
So i've had an S13 for several years now, and never seem to work out my damn idle issues. It's a redtop, with most of the bolt-on's you can get, but nothing internal done, and still the original turbo, cams, etc. I've replaced the temp sending unit, plugs, ignitor, IACV, double and triple checked for boost leaks, a couple thermostats, boost controller, messed with the A/F ratio, new O2 sensor, etc etc etc. It finally idles good most of the time, but randomly starts to wonder about between 500-1000 rpm. I see a voltage drop from about 13.5V down to 12.5, then back to 13.5 just before the rpms drop (voltage down, revs down, voltage up, revs up). It'll do this for 2-5 minutes, then idle normal again. I've done the re-grounding of the the sensors as I found on this site, new cables for the alternator, battery is brand new. No power steering, no A/C. What else...S14 alternator...all electronics seem fine, but the lights do flicker with the voltage.
Ground issue, maybe? Not sure what would cause something so intermittent.
Thanks in advance.
krislin is offline   Reply With Quote
Old 02-14-2009, 06:44 PM   #2
at23
at23's Avatar
at23 is making a name for him/her selfat23 is making a name for him/her self
Send a message via AIM to at23 Send a message via Yahoo to at23
Timing perhaps?
Socal-drift.com ,gay jokes aplenty.
SDDrift.com,haven for Zilvia rejects.
at23 is offline   Reply With Quote
