Old 02-15-2009, 10:12 PM   #1
wrxn240
wrxn240 is on the path to ruinwrxn240 is on the path to ruin
Car is in gear when in neutral
I just started my car up for the first time after doing a sohc to dohc swap. I don't have the rear half of my driveshaft in nor do I have the diff in. When my car is in neutral, my driveshaft spins, but if the clutch is in, it won't spin. What seems to be the problem?
wrxn240 is offline   Reply With Quote
Old 02-15-2009, 10:31 PM   #2
projectRDM
projectRDM's Avatar
That's normal. There's no resistance on the output shaft.
FORMERLY R240NA
Old 02-15-2009, 10:39 PM   #3
jorge1190
jorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to all
Yes i experienced the same thing and freaked out a while back. Once you bolt everything up it will be fine.
jorge1190 is offline   Reply With Quote
Old 02-15-2009, 10:56 PM   #4
VanduzerLancerES
VanduzerLancerES's Avatar
VanduzerLancerES is an unknown quantity at this point
Everyone freaks out when they do this.. Its normal Your goood. How long did it take you to do the swap?
VanduzerLancerES is offline   Reply With Quote
