Old 02-28-2009, 10:02 AM   #1
s13pignose
s13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of light
Will 96-98 KA injectors work on a 95 KA
Looking at getting injectors with low miles on em for my 95 s14..just wondering if injectors off a 96-98 would work and everything be plug and play?
Thanks
s13pignose is offline   Reply With Quote
Old 02-28-2009, 10:07 AM   #2
!Zar!
!Zar!'s Avatar
Yup. Same.
Just make sure to replace the Orings and lube the injector before install.
Old 02-28-2009, 10:14 AM   #3
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Yup. Same.
What he said^^^
Old 02-28-2009, 10:27 AM   #4
s13pignose
You mean lube the rings or injectors themselves? Like I read you could use vaseline on the rings.
Thanks for fast response
Old 02-28-2009, 10:45 AM   #5
projectRDM
projectRDM's Avatar
91-98 all the same. You can use 93-01 Altimas as well.
FORMERLY R240NA
Old 02-28-2009, 11:04 AM   #6
undercoverdjay
undercoverdjay is making a name for him/her selfundercoverdjay is making a name for him/her self
Send a message via AIM to undercoverdjay
Vasoline on rubber o-rings will rot the rubber in no time. Kind of why you cant use a latex condom with oil-based lube when you're doing the deed. Use a waterbased lube for the injector and it'll slide right in and not to any damage to the injector/o-ring. Ive honestly used KY before and it worked just fine, lol.
undercoverdjay is offline   Reply With Quote
Old 02-28-2009, 11:49 AM   #7
projectRDM
projectRDM's Avatar
I dab of drop of WD40 on them. Never had a problem, it dries fast enough to not leave a residue.
FORMERLY R240NA
Old 02-28-2009, 12:31 PM   #8
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
What about using motor oil, is that bad? Also, a friend of mine just took some of the fuel lingering in the rail and dabbed it on the o-ring to lube it up on his SR. Then again, he has a ton of problems so I dunno how good of an idea that was.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 02-28-2009, 12:45 PM   #9
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
I dip them in motor oil all the time when I install injectors, works fine everytime.
Old 02-28-2009, 01:07 PM   #10
s13pignose
Alright I'll be sure to skip the vaseline...good call guys. Thanks.
Hey on another subject my new nissan distributor cap and ign. rotor came in this morning, so I put em on shortly after. Everything went smooth but I noticed some differences between the old and new rotor. The new one had like this thin layer of black epoxy looking stuff on the tip of the conductor..I mean the top metal part of the rotor. The old one didn't. I thought it was some sorta protective tape or something at first, so I tried gently prying edge up on the bottom. Didn't peel up and infact a piece of it flaked off about the size of a grain of salt (no biggie), so I assumed it was there on purpose and for good and left well alone.
Car started and drove fine..and I pulled each plug wire to make sure all plugs fired. Also do any of you pack the wire terminals on the top of the cap for moisture? I skipped on that..since i don't plan to spray under the hood any time soon.
Thanks again
Old 02-28-2009, 05:34 PM   #11
LA_phantom_240
Thanks again
I always apply Permatex Dielectric grease to the boots (inside and out) on the plugs and distributor cap boots.
