Old 03-04-2009, 09:08 PM   #1
SoCal-s130
Clutch or Transmission Problems. Help!
So tonight on the way home from work I was exiting the freeway and hit a little bump then after that heard a sort of clunk right under me. When I stopped at a light I tried to put it in gear and it was like I was trying to switch into gear without pushing the clutch in and then it stalled. The clutch got noticeably stiffer and it isn't even engaging anymore. With the car off and the clutch not engaged the gears go through fine. Anybody have any ideas?
Old 03-04-2009, 10:22 PM   #2
SoCal-s130
Anyone have any ideas? This is my daily driver aha.
Old 03-04-2009, 10:29 PM   #3
hapa_s13
hapa_s13 is an unknown quantity at this point
might have been your master cylinder or slave cylinder...that's just from the sounds of the shifting problem and clutch problem though. Im not to sure about how a bump might have been able to do that so meh.
hapa_s13 is offline   Reply With Quote
Old 03-05-2009, 12:37 PM   #4
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
bent clutch fork??? maybe. if clutch is hydraulic check fluids if good check the lines maybe one got pinched. other than that ????? sounds like the clunk might of been you hitting something and pinching a line so i'd go with that
godsmack is offline   Reply With Quote
Old 03-05-2009, 02:18 PM   #5
hapa_s13
^ agreed. I totally overlooked the lines..never had that as a problem
Old 03-05-2009, 06:16 PM   #6
zenki.life
zenki.life's Avatar
zenki.life is an unknown quantity at this point
Send a message via AIM to zenki.life
cluch fork!!!!! i was just underneath the car today and man that thing sticks out enough for you to have damaged it. especially if the car is lowed
Originally Posted by super240s14 View Post
man you all are ass holes...... and that is rude to talk like that on zilvia im reporting all you...... ZILVIA ADMINISTRATION PLEASE BANNED ALL THREE OF THESE DUDES
^^another person learns the perils of "stupid posting" on zilvia, too bad none will care.
zenki.life is offline   Reply With Quote
Old 03-05-2009, 09:17 PM   #7
zenki.life
zenki.life's Avatar
^^^ **lowered** not lowed haha
Old 03-05-2009, 09:42 PM   #8
initial_drifter
initial_drifter's Avatar
initial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of light
Was it raining by any chance? If it was and water got onto the clutch disc it would cause it to just slip like a mother.
In other words, if you have a decently sized hole for any kind of debris/liquids to get in that's gonna give you hell
initial_drifter is offline   Reply With Quote
Old 03-05-2009, 11:15 PM   #9
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Kyle, what you just described is pretty much exactly what I felt when one of the springs on my clutch disk busted itself out and wedged itself against the pressure plate.
You can still drive it if you don't have a clutch start switch... Just start the car in first, and shift without the clutch. Float through the gears.
-Kyle
Old 03-05-2009, 11:21 PM   #10
DDDsquad_s13panda
DDDsquad_s13panda is making a name for him/her selfDDDsquad_s13panda is making a name for him/her self
did u check you slave cylinder? might wanna check that first.
DDDsquad_s13panda is offline   Reply With Quote
Old 03-06-2009, 02:00 AM   #11
soreballz
soreballz's Avatar
Trader Rating: (22)
^It it was the slave cylinder, he'd have NO pedal. He said the pedal is super heavy.
-Kyle
Old 03-06-2009, 03:17 AM   #12
nissan240
nissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to all
mostl likely its what soreballz said! but if you recently did your clutch and flywheel recently it could be one of your bolts coming loose from your flywheel! you'll hear the flywheel clunking when when stepping on the clutch peddle!
nissan240 is offline   Reply With Quote
Old 03-06-2009, 09:24 AM   #13
DDDsquad_s13panda
oh yeah. hahah.
