Old 03-18-2009, 03:25 PM   #1
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Tranny's apart, coat with WD40?
I really dont want the gears to dry out and rust, should I soak the gears with wd40? Im hunting a retaining pin that walked up into one of the bearings.
Some people say wd40 is a no-no on the bearings.
Bigsyke is offline   Reply With Quote
Old 03-18-2009, 03:26 PM   #2
projectRDM
projectRDM's Avatar
How long do you plan on leaving it apart?
FORMERLY R240NA
Old 03-18-2009, 03:26 PM   #3
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
coat with tranny fluid and cover with something dry
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 03-18-2009, 03:31 PM   #4
Bigsyke
Bigsyke's Avatar
well im inspecting this tranny, because I have a feeling I was ripped off. - makes some clicking sounds while turning the input shaft.
I plan on leaving it apart for 1 week.
I will however put the casing back togeather.
Old 03-18-2009, 03:32 PM   #5
Sileighty_85
Sileighty_85's Avatar
coat with gear oil and put in a plastic bag
I had mine apart in a plastic bag for 6 months without a problem
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-18-2009, 03:47 PM   #6
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
wd40 will kill bearings
gears?should be ok but just use oil to be safe
in a zip lock bag works good
built ka-t
importdude is offline   Reply With Quote
