![]() As the title says, my brake lights fail to work, and I dont know when this started happening, just found out last night.
1. Checked fuses and fuse box under the left side of the dash, theyre OK. 2. Checked bulbs, they work too. 3. When my headlights are on, the rear bulbs are on, as normal. Nothing changes when I depress the brake pedal. According to Chilton's manual diagram, there is a set of switches under the driver's side of the dash, including the stop light switch. However, I cannot locate this as when I take a look under the dash, it represents nothing like the actual diagram. If i could locate that little switch, it may very well solve my problem. Or can the problem be something else? Can anyone help? Thanks in advance. |
![]() Join Date: Nov 2001
Check the power output going to the bulbs when the brakes are depressed, see if you are getting current.
Check the switch which is attached to the brake pedal, that is what activates the brake lamps.. make sure that the switch is working. If your parking lamps work, your circuit should be okay because the brakes and parking lamps I *beleive* are on the same circuit.. same fuse, etc. I dont think there is a relay, but there may be. Chiltons is crapola, an FSM would be much more useful in trying to resolve this problem. - Mike |
did you recently install a new deck in your car?
thats what screwed up my taillights was a new CD player....something was gtounding out or something
Who the hell needs a sig anyhow |
#5 | |||
Thanks for all of your responses
