Old 04-02-2009, 06:51 PM   #1
driver11324
driver11324's Avatar
driver11324 is an unknown quantity at this point
S14 Blinker problem
First, I have searched and there is one thread about this, but no answer. Also, I have studied the FSM and got nothing out of it. Anyway, I have a Zenki s14 and changed the front over to a kouki. Now because there are bigger bulbs in the zenki blinkers and smaller in the kouki, the blinkers blink really fast, acting as if a bulb was out. No bulbs are out. Can I put a resistor in the socket so that the blinker relay gets somewhat "tricked?" What other options do I have.
driver11324 is offline   Reply With Quote
Old 04-02-2009, 07:51 PM   #2
projectRDM
projectRDM's Avatar
Bulb size has nothing to do with it. You've got another issue somewhere.
FORMERLY R240NA
Old 04-03-2009, 05:56 AM   #3
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
I swapped my rear turn signals to LED bulbs and it double flashes on the turn signals but flashes normal on the hazards. If I swap back to the normal bulbs it works fine. It's has to be a resistance issue, I was thinking of putting some kind of resistor also but I'm not sure what size?
HYPNOTIK is offline   Reply With Quote
Old 04-03-2009, 03:56 PM   #4
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
Don't use LED's.. Thats just a bad idea. It takes a dickload of LED's to match the light output of regular incandescant. Like RDM said... Your issue is somewhere else. Perhaps you have the completely wrong bulb altogether.. Theres a shit ton of bulbs that look like 194s, 168s, etc... may be the same issue in your case..
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 04-03-2009, 04:25 PM   #5
cotbu
cotbu's Avatar
You're out of blinker fluid!
