Old 04-19-2009, 07:33 AM   #1
SuicidnS13
SuicidnS13's Avatar
SuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruin
Is wheel clearance for the z32 rears the same as the fronts?
I had to put a 15mm spacer on my front wheels to clear my z32 brakes with 350z track rotors. Im about to install z32 rears and ebrake once my car comes back from the paint and body shop. Is the wheel clearance needed about the same or do the rears not need as much wheel clearance?
SuicidnS13 is offline   Reply With Quote
Old 04-19-2009, 08:53 AM   #2
cdlong
it's no where near as much, though still worse than stock. from what i remember (i'm nowhere near my car) the rear calipers sit behind the rotor mounting face so you shouldn't have any problems.
cdlong is offline   Reply With Quote
