Old 04-17-2009, 01:01 PM   #1
surge s14
surge s14's Avatar
surge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymore
Stupid 5 lug qestion for S13
i bought some 5 lug parts form a SE s14 and iam installing my energy master set
that i want to use my question is what do i use and what not to use
heres a pic of what i bought
your input is much appreciated
surge s14 is offline   Reply With Quote
Old 04-17-2009, 01:04 PM   #2
palmdale_mob
palmdale_mob's Avatar
palmdale_mob is an unknown quantity at this point
For the rear you will only need the hub and rotor
For the front you need hub, rotor, lca, and knuckle
palmdale_mob is offline   Reply With Quote
Old 04-17-2009, 01:06 PM   #3
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
iirc, you can use the rears. u can only use the fronts by using the lca and all that. the rears you have to use n/a z32 hubs.
someone else can clarify the front part components
lexus baby
5t341tH is offline   Reply With Quote
Old 04-17-2009, 01:25 PM   #4
surge s14
surge s14's Avatar
thanks guys
im having a real hard time geting the hubs off the s14 parts can someone let me in on the secret
Old 04-17-2009, 01:31 PM   #5
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
WHAT!? if ur sayin you cant use rear s14 hubs thats incorrect...u can...period...
Originally Posted by surge s14 View Post
thanks guys
its called a hammer...remove the four bolts holding the hub to the shield and knuckle and give it some love taps and some PB blaster...
P.S. you only suppose to remove the rear hubs...the knuckle LCA and hubs on the front s14 parts bolt right in...
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 04-17-2009, 01:34 PM   #6
bullitt519
bullitt519 is an unknown quantity at this point
pulley puller or hub puller will get them off if stuck
bullitt519 is offline   Reply With Quote
Old 04-17-2009, 01:46 PM   #7
palmdale_mob
Take off those 4 bolts on the back of the hub, and put in work on that axle
Old 04-17-2009, 01:46 PM   #8
surge s14
surge s14's Avatar
i removed the big 30mm bolt
i thought the cv shaft would fall out but no luck here i want hammer bash it out . with the shaft in the way i cant get to the bolts behind the knuckles
Old 04-17-2009, 01:49 PM   #9
palmdale_mob
Turn the shaft and there is little grooves that will line up so you can get to those bolts
Old 04-17-2009, 01:53 PM   #10
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
ill answer more when i get home, work doesnt let me see pics...till then
PSN
Old 04-17-2009, 01:59 PM   #11
Sileighty_85
Sileighty_85's Avatar
PB blaster
Let soak
put nut on till flush with top of axle shaft
Smack with mallet
It is possible to get to the bolts with the shaft still in
You just need to roatate the shaft until the the slotted section of that Lump?? lines up with the bolt
Ive done 5 lugs swaps while everthing is still on the car.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-17-2009, 03:29 PM   #12
nrmskate
nrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura about
Like the guy above said, there will be little grooves.
You'll see it and look at it, then finally figure it out and be like, "Wow, im a dumbass, shoulda noticed that"
nrmskate is offline   Reply With Quote
Old 04-17-2009, 03:44 PM   #13
surge s14
surge s14's Avatar
yeah i got the bolts out i picked up some pb blaster and well still i cant get it off
iv been beating it with a hammer...lol
and it budged but not much
Old 04-17-2009, 03:46 PM   #14
Sileighty_85
Get a bigger hammer....hahaha
You need something with some umph
A ball peen wont cut it
後輪駆動車1番
1986 SR86 - 200ish
Old 04-17-2009, 04:15 PM   #15
WERDdabuilder
WERDdabuilder's Avatar
get a block of wood. place it against the axle and hit that shit with the BFH.
When the power of love overcomes the love of power, the world will know peace
Old 04-17-2009, 04:32 PM   #16
palmdale_mob
Are you stuck trying to hit out the axle?
If so I ended up with the same situation and ended up going to my friends shop and throwing the whole assembly in the press
Ir worst comes to worst thats what you might have to do, I bent my knuckle when I did it so just be careful
Old 04-18-2009, 08:39 AM   #17
bullitt519
pulley puller or hub puller will get your hub off without a f'ing hammer they are free to use at alot of autoparts stores
example:
Old 04-18-2009, 12:17 PM   #18
surge s14
surge s14's Avatar
yeah i was fustrated i was taking a sludge hammer to the axle and holy crap moved maybe a 1/4in im going to try the hub puller today or on the weekend
i left it soaking with a full can of pb blaster over night
ill let you all know how it goes incase someone else runs into this problem.
Old 04-20-2009, 07:12 PM   #19
surge s14
surge s14's Avatar
i tryed the puller with nothing to show.
im going to send it out to a buddy with a press and see how that goes.
im just going to move on to the front...
now the knuckles for the front all i do is swap the s13 to the s14 assmbaly and bolt on right?
Old 04-20-2009, 07:15 PM   #20
iRONDONkey
iRONDONkey is on a distinguished road
quick question.
how big is the axle nut for the rear?
32mm? 34mm?
it's on my 89 240sx coupe, and i need to buy a socket for it, to take it out.
iRONDONkey is offline   Reply With Quote
Old 04-20-2009, 07:16 PM   #21
surge s14
surge s14's Avatar
its a 36mm
Old 04-20-2009, 07:23 PM   #22
lost240soul
lost240soul's Avatar
lost240soul is on the path to ruinlost240soul is on the path to ruinlost240soul is on the path to ruin
Front on S13 is 30mm, S14 is 32mm. Rear is 36mm on both cars.. i think some one correct me if im wrong..
lost240soul is offline   Reply With Quote
Old 04-20-2009, 07:27 PM   #23
whyrun?
whyrun? is an unknown quantity at this point
if you dont need the axles, just ut the nut back on the spline and whale on that fucker.
the hub was stuck in the upright when i did mine so i just took the 36mm socket, placed it on the back on the hub and hit it a few good times with a BFH. came undone in minutes
whyrun? is offline   Reply With Quote
Old 04-20-2009, 08:10 PM   #24
DCP94
DCP94's Avatar
DCP94 is an unknown quantity at this point
example:
when i did my 5 lug my 4 lug hub was stuck on pretty well...use the pulley puller like above its the easiest way and you can return it after you use it!! your best option imo
DCP94 is offline   Reply With Quote
Old 04-21-2009, 12:43 AM   #25
surge s14
surge s14's Avatar
i used it and a impact gun it didn't come out
Old 04-21-2009, 11:51 AM   #26
projectRDM
projectRDM's Avatar
Not a good suggestion. If you don't need the axle, why put the nut back on? If you hit it hard enough the nut will crown the axle's threads, making the nut impossible to get off.
I've only had one really stuck axle before, it was a set of R32 rear uprights, I put the uprights on top of a vice and used a sledgehammer. It still took maybe a dozen good hits. Using a hub puller isn't always optimal because you can pull the hub out of the bearing.
FORMERLY R240NA
Old 04-21-2009, 12:50 PM   #27
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
yup yup ....shits so messy when the hub pulls from the bearing...id say keep flooding it wiht some pb blasterfor one day and taking a piece of wood on top of the axle and start whaling at it...less chance of u screwing up on the axle smashing out ... another thing u can do is, get one of those autozone claws...the big ass one...cut out the dust shield, and anchor the claw arms to the knuckle...and start cranking on the bitch...hope that makes sense
PSN
Old 04-21-2009, 07:13 PM   #28
DCP94
DCP94's Avatar
lol so many ways to do this...i hope you gotten it off by now
