Old 04-22-2009, 01:12 AM   #1
mrchomponthis
mrchomponthis's Avatar
mrchomponthis is an unknown quantity at this point
transmission install on s13 w/ sr20
I am looking for any tips on how to reinstall my transmission i had to put in a new clutch and i had to replace my flywheel bolts and i have my clutch inplace and aligned. I was told to loosen the motor mounts, try putting in the transmission upside down on at a 90 degree angle. I can't seem to get the right and to get the joke in. the top part of the transmission keeps hitting the body of the car and it has become very frustrating. me and 2 of my buddies are planning to get it in tomorrow. PLEASE IF YOU GUYS HAVE ANY OTHER TIPS PLEASE CHIME IN. it would be much appreciated, or if you can lend a helping hand in the process i am in Garden Grove
mrchomponthis is offline   Reply With Quote
Old 04-22-2009, 01:16 AM   #2
gunmetalr32
gunmetalr32's Avatar
gunmetalr32 is on a distinguished road
i have a trick or two.... try loosening the motor mounts and jack up the front crank pulley with a rubber block till the motor is in a better angle then it should go right in...
NEED S14 KOUKI VALANCES, S14 NAVAN SIDE SKIRTS, S14 KOUKI OEM JDM LIP HIT ME UP!!
gunmetalr32 is offline   Reply With Quote
Old 04-22-2009, 01:16 AM   #3
gunmetalr32
thats if you dont have a crane/cherry picker
Old 04-22-2009, 01:21 AM   #4
mrchomponthis
i have a cherry picker. wouldn't that damage the crank pulley rapping a chain around it... i also still have all belts on.
Old 04-22-2009, 01:28 AM   #5
gunmetalr32
if you have a crane lift up the front of the motor, not by the crank ...
Old 04-22-2009, 02:24 AM   #6
VQMaxFan
VQMaxFan's Avatar
VQMaxFan is on a distinguished road
Just put a big block of wood on a jack, and jack up on the motor a little bit from the oil pan.
Get as many ppl as you can to help maneuver the tranny, use a service jack or something to help. What took me and one friend about 2 and a half hours to do, took me and 2 friends 30 minutes to do. Just try to get the trans in as straight as possible!
VQMaxFan is offline   Reply With Quote
Old 04-22-2009, 02:27 AM   #7
mrchomponthis
thanks for the help. i am determined to get this thing in tomorrow. I have seen many threads on doing this but everyone has there own ideas and ways but with NO PICTURES! other people said they just got it in like magic and would never try to do it again.
Old 04-22-2009, 05:11 PM   #8
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
If there is no coolant in it, disconnect the radiator it will tip more, or just take the top mounts out so it tips with the motor.
Keep it turned and it will go in. I did it myself twice, took maybe 30 minutes, well the actual process takes like 40 seconds once you get a burst of energy.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 04-22-2009, 05:26 PM   #9
Rapier46
Rapier46's Avatar
Rapier46 is an unknown quantity at this point
Send a message via AIM to Rapier46
lol. take off the shifter and slide it on...its extremely easy.
Left hand drive 240sx's ARE NOT SILVIAS.
Rapier46 is offline   Reply With Quote
Old 04-23-2009, 12:21 AM   #10
georgesal
georgesal's Avatar
georgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to behold
bang the trans tunnel as close as you can to the motor, you know right where the bell housing hits the tunnel, just hit it with a hammer and then its really easy to put your trans in and out whenever you want.
georgesal is offline   Reply With Quote
Old 04-23-2009, 12:23 AM   #11
mrchomponthis
trans is in thanks for the help im so stoked right now
Old 04-23-2009, 01:26 AM   #12
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
I had a bitch of a time doing it myself.
I was literally bench pressing that fucking tranny.
SochBAT is offline   Reply With Quote
Old 04-23-2009, 11:52 AM   #13
dmax_silvia_s13
dmax_silvia_s13's Avatar
dmax_silvia_s13 is an unknown quantity at this point
Send a message via MSN to dmax_silvia_s13
Haha same here it was my first time and I did it by myself. It just takes some patience and some time.
I had a jack under my engine and a tranny jack under the tranny and just jack the engine up and keep trying different things with the tranny and itll eventually go in.
You dont need to turn the tranny 90 degrees thats just for a ka tranny im pretty sure.
Edit: Just saw you got it in so nevermind.
Brandon Kelly
1990 Nissan Silvia
dmax_silvia_s13 is offline   Reply With Quote
Old 04-23-2009, 12:11 PM   #14
gijoe69
gijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant future
Send a message via AIM to gijoe69
lube her up and be sure to drink a couple of beers when installing
gijoe69 is offline   Reply With Quote
Old 04-23-2009, 01:14 PM   #15
mrchomponthis
i drank plenty of beers and honestly it just slipped right in lol
