Old 04-24-2009, 09:35 AM   #1
duce_n_135
duce_n_135 is an unknown quantity at this point
Alternator Problem, please help...
Hello, I just recently bought a 93' 240sx shell. It has an sr swap previously and now when i put the ka24de back in it, it drains the battery like no other. I did a check, and found out that when i plug in the alternator plug, it shorted out the whole car. There's continuity when i test the plug. It's weird. Any idea of where this short could be or what cause this problem? i literally rip out every wire trying to track it out.
Thanks in advance for the reply.
duce_n_135 is offline   Reply With Quote
Old 04-25-2009, 08:18 AM   #2
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
check under the terminal on the alt, there should be a plastic washer. if its gone or broken, it will short the main fuse. good luck.
aNskY is offline   Reply With Quote
