Old 11-12-2008, 06:18 AM   #1
fatlizzard
fatlizzard's Avatar
fatlizzard is on the path to ruinfatlizzard is on the path to ruin
Idler sprocket fix
Anybody know a way to fix stripped threads for the timing chain idler sprocket aside from getting a new head?
Will using a slightly longer bolt (1/4") work?
fatlizzard is offline   Reply With Quote
Old 11-12-2008, 11:10 AM   #2
projectRDM
projectRDM's Avatar
I'd rethread or helicoil before putting a longer bolt in, the depth isn't really workable, and doing that only gives you a solid bite at the end of the bolt, the opposite of where you need it.
FORMERLY R240NA
Old 04-27-2009, 08:54 PM   #3
In The Works
In The Works's Avatar
In The Works is an unknown quantity at this point
Did you get this fixed? If so, How? I just had the same thing happen to mine!
In The Works is offline   Reply With Quote
