Old 07-10-2003, 05:00 PM   #1
method2833
method2833's Avatar
method2833 is an unknown quantity at this point
Send a message via AIM to method2833
need help with idle problems
for some reason, my '91 keeps dying. it seems to do it when I decelerate hard, or sometimes just under normal deceleration. And sometimes, fairly frequently, under deceleration, when i'm almost stopped, the car will go to like 200-300 rpm, and almost die, but when i get completely stopped, it goes back up to normal idle, and runs just fine. I seem to get these problems more often when it's raining or damp outside. Could it be a sensor somewhere, like the MAF? Any help would be appreciated. Thanks
Team Mullet - Its not just a hair style its a lifestyle
method2833 is offline   Reply With Quote
Old 07-11-2003, 12:52 AM   #2
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
I know it doesn't help, but if it makes u feel any better, my SR does the same damn thing
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 07-11-2003, 09:43 AM   #3
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
my car did the same thing, if i apply brake slowly for a light, it'll just stall, sometimes it stalls on a freeway offram (imagen that, you are going off the freeway at a speed too fast for your own good, and than your engine dies, giving out power steering and power brakes....), i've found my struggle to be the ICV, i've made my own intake, and it wasn't doing very good, i switched to AEM (for the carb#) and now it runs fine.
so if you have an after market intake, check on all the hoses make sure they are correcly connected, and that there's no sevear bends on the rubber tubing causing a restricted air flow.
240meowth is offline   Reply With Quote
