Old 05-14-2009, 08:33 AM   #31
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
Originally Posted by SILVIA_KIDs14.5 View Post
go solid and call it a day never again have to replace them it would though have ben easier to get the bushings pressed out
you're wrong, you can't just "press em out".
this isn't' a control arm bushing or something.
the subrame is massive in relation to things that you normally press bushings in and out of.
energy suspension's published recommendation is to use a torch to heat up the outer casing so the rubber "slides" out. they specifically say NOT to use a press.
clark is offline   Reply With Quote
Old 05-14-2009, 08:42 AM   #32
projectRDM
projectRDM's Avatar
Agreed. using a press is possible, however you need at minimum a 20 ton model, two other people to help hold the subframe, and prayers that you don't deform the forward mounting points when the load comes down and starts pressing. Torching is far easier.
FORMERLY R240NA
Old 05-14-2009, 07:10 PM   #33
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
IMHO the airsaw is the best because you will die a toxic death burning it.
You can do it with an air saw, you poke the sawblade in the cavity in the OEM bushing and cut a slit in the outer ring OF THE BUSHING being careful not to cut the subframe ring. It helps to saw a little from the top side and a little from the bottom side. Once the slit is cut shove a big flat head screw driver in there and once the tension of the bushing's outer ring is compromised, it just pops right out.
we burned this one out just to show you clearly what you need to cut
MAX PRODUCTS FORUM - SUBFRAME RISER
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 05-14-2009, 07:21 PM   #34
projectRDM
projectRDM's Avatar
No one is going to die a toxic death unless they stand over it and breath while it burns. You torch it, walk away and eat lunch, come back after the fire has gone out. If that worries you, stand a good distance and watch, but it's not like the fire will continue and melt the subframe. It's steel. Have to be a little hotter to do any damage. Once the bushing falls out on it's own you throw a hose on it, done.
FORMERLY R240NA
Old 05-14-2009, 08:09 PM   #35
bing
bing will become famous soon enoughbing will become famous soon enoughbing will become famous soon enoughbing will become famous soon enoughbing will become famous soon enough
BFC - big fucking chisel
BFH - big fucking hammer
that is all.
www.son240sx.org /// www.nyspeed.com
bing is offline   Reply With Quote
Old 05-15-2009, 09:40 AM   #36
s13.dark1
s13.dark1's Avatar
s13.dark1 is making a name for him/her selfs13.dark1 is making a name for him/her self
hopefully this thread is helpfull to someone that want isnt really sure and wanted to get info plus pics great job all!
you better cut, weld, and paste that sh!t
http://zilvia.net/f/sale-items/24340...kets-more.html
s13.dark1 is offline   Reply With Quote
Old 05-15-2009, 03:30 PM   #37
Lith
Lith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enough
Send a message via ICQ to Lith Send a message via AIM to Lith Send a message via MSN to Lith Send a message via Yahoo to Lith
What I did is this; I bought another S14 subframe and I got a local shop to take out the bushings. Then I sandblasted/powder coated the subframe. Got the same shop to press in the new bushings. Also, that included the diff bushings on the subframe (S14's have this, S13's don't).
I ended up paying 100 bucks for the shop to take out the bushings and press in new ones.. and another 100 bucks for sandblasting and powder coating and the subframe was 50 bucks. So that's 250 bucks.. imo, well worth it since this is a quite a bit of work for one person.
Also, the bushings I got are the nismo ones, but I don't recall what I paid for them. Needless to say, car feels much better w/o that lose subframe in the back.
Lith is offline   Reply With Quote
Old 05-15-2009, 08:49 PM   #38
hegamiz
hegamiz's Avatar
hegamiz is just really nicehegamiz is just really nicehegamiz is just really nicehegamiz is just really nicehegamiz is just really nicehegamiz is just really nicehegamiz is just really nicehegamiz is just really nicehegamiz is just really nice
hahaha definitely... i haven't gotten that far into my first project, reading this shed some light on what to avoid lol
hegamiz is offline   Reply With Quote
Old 05-16-2009, 09:08 AM   #39
drift Kid
drift Kid's Avatar
drift Kid is just really nicedrift Kid is just really nicedrift Kid is just really nicedrift Kid is just really nicedrift Kid is just really nicedrift Kid is just really nicedrift Kid is just really nicedrift Kid is just really nicedrift Kid is just really nice
Send a message via AIM to drift Kid
awesome thread.. what should the drifter guys go with that has the welded diff.. my bushing is beyond shot.. solid or regular bushing like the enegry suspension kits.. i really dont want to use spacers..
Exclusive Auto Garage
drift Kid is offline   Reply With Quote
Old 07-13-2009, 01:17 PM   #40
s13.dark1
s13.dark1's Avatar
go with solid bushings
Old 07-13-2009, 04:26 PM   #41
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
I had to stand over all 4 because the fire kept going out. I had to use a screw driver and churn the rubber so the flame could be exposed to new rubber.
Thought I was going to die the next day, my sinus's were caked with rubber and everytime I blew my nose it would be pure black goo.
Man and to think im going to have to do that again when i get another S14. Worth it though!
Bigsyke is offline   Reply With Quote
Old 07-13-2009, 05:09 PM   #42
projectRDM
projectRDM's Avatar
Fire wasn't hot enough. Use some gas to get it going. It will take care of itself.
FORMERLY R240NA
Old 07-13-2009, 05:44 PM   #43
Lev
Lev is making his/her stupidity well-knownLev is making his/her stupidity well-knownLev is making his/her stupidity well-knownLev is making his/her stupidity well-knownLev is making his/her stupidity well-known
Having just done this last weekend, you don't need fire. You don't even need to remove the subframe. Here is how we did it at a mechanic's shop:
1. Unbolt stuff until you can lower two of the subframe bushings clear of the bolts. You need to disconnect stuff but it will not affect your alignment. I believe it was just the coilover, and one l-shaped piece of metal as well as the subframe. I don't remember all the specifict but I do remember that we didn't have to drop the driveshaft or disconnect any control arms (so no need for a new alignment). The driver side we had to drop the back half of the exhaust. One thing to watch out for is that you don't push down too hard on the subframe because you dont' want to snap your brake lines, 2 inches past the bolt should be plenty of room anyway.
2. Once you are clear of the bolt, use a sharp object to pierce the center rubber portion.
3. Use a wood bit on the sawzall to cut out most of the rubber center.
4. Put on a metal bit and cut through both metal cylinders of the subframe bushing, careful as to not cut the subframe ring of course. Three cuts should do it.
5. Run an air chisel up the cuts and the bushing should fall right out as soon as you release tension.
6. Clean out the subframe ring with a course than a fine wire brush
7. If you have poly bushings, which you probably should get (personal opinion though only) they should just slide in. I used PowerFlex Street polyurethane bushings and they slid right in without any lube or anything.
Obviously for this method you need access to a lift or a way to get the rear end up high enough for sawzall clearance and an air chisel. We used an 18v dewalt sawzall so you don't need anything incredibly fancy. The entire job took about 3 hours, but that's because it took until the second bushing to figure out the best way to do it (the first bushing took like 1.5 hours lol).
Edit: This is on an S14 subframe, I don't think the S13 is too different.
Lev is offline   Reply With Quote
Old 07-13-2009, 05:48 PM   #44
Bigsyke
Bigsyke's Avatar
^^^Apologies, but that wont work with solids.
Old 07-13-2009, 08:51 PM   #45
ixfxi
Guest
Posts: n/a
hahah russ, syke probably was using matches. :-)
seriously, propane torch brotha... its all thats needed.
Old 07-14-2009, 02:23 PM   #46
Lev
Didn't know that. Regardless though, unless you are using a bushing that requires a press (OEM I think, but why would you do that? or a solid bushing, which 99% of people don't need) the method that I outlined above will work and will be a hell of a lot easier and cheaper than removing the subframe, disconnecting everything on and around it, burning out the rubber then cutting the metal ring, reinstalling everything and then having to take the car in for alignment (my method doesn't mess with any alignment related arms).
