Old 07-14-2003, 08:22 AM   #1
nis-s13
nis-s13 is an unknown quantity at this point
s13 lsd?
whats the easiest way to find out if you have lsd? isn't there suppose to be like marking on the diff? just picked up a 91' coupe se
for $500 super cheap........
nis-s13 is offline   Reply With Quote
Old 07-14-2003, 08:27 AM   #2
FoCaL
FoCaL is an unknown quantity at this point
Send a message via MSN to FoCaL
Im still a noob enough not to know how to look for in marking and stuff. However, if you have hicas, you do 100% for sure have an lsd. If you have abs its most likley that you have an lsd but not 100%. If you dont have hicas or abs then you dont have an lsd. Hope this helps some.
Regards
FoCaL is offline   Reply With Quote
Old 07-14-2003, 08:35 AM   #3
BSeay
BSeay's Avatar
BSeay is an unknown quantity at this point
Send a message via AIM to BSeay
Jack up the rear end, spin one of the tires if they both spin, LSD, then dont then your open diff my friend.
1995 240SX SE - Sold
BSeay is offline   Reply With Quote
Old 07-14-2003, 08:41 AM   #4
FoCaL
Not always true. Ive had a 93 camaro 6cyl. I know it has an open diff. and both tires would spin. Also my GSR has an open diff and both tires pun also. Just my experience.
Regards
Old 07-14-2003, 08:52 AM   #5
Dousan_PG
Dousan_PG's Avatar
for s13/s14/s15
jack up rear
put can in neutral and ebrake off.
turn one wheel
open diff other will turn other direction (opposite of the one your turning.
also if you have a friend hold the other wheel so it wont move and you turn your will. the open diff will turn your wheel easily
vlsd will give some (quite abit) of resistance depending in what condition its in.
good luck
Aaron
Pink GodziRa
Old 07-14-2003, 11:51 AM   #6
sykikchimp
WOW addicted
sykikchimp's Avatar
there's always the tried and true.. "dump the clutch" method.
Old 07-16-2003, 11:50 PM   #7
bobmeindertsma
bobmeindertsma's Avatar
bobmeindertsma is an unknown quantity at this point
thats how i found out.
in an empty parking lot.
dumped it and left 2 hefty black beauties behind.
hehe
bobmeindertsma is offline   Reply With Quote
Old 07-17-2003, 12:19 AM   #8
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
hey nis-S13...is your name preston?
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 07-17-2003, 03:19 PM   #9
StreetConcept
StreetConcept's Avatar
StreetConcept is an unknown quantity at this point
im not sure
i need to jack it up... but every time i dump the clutch i leave 1 and a half black beauties behind me.. my tires start with both and then one just keeps spinning while the other one catches... im gunna jack it up but do you guys think i have one?
<<StreetConcept>>
\m/(0)^(0)\m/ .. Rock on...
"Thats a Flying Potato? I thought it was a 240!"
StreetConcept is offline   Reply With Quote
Old 07-17-2003, 03:23 PM   #10
Dousan_PG
Dousan_PG's Avatar
jack it up
yes you can do burnouts and leave 2 marks w/ open diff
jacking it up or opening the diff is the MOST ACCURATE way to find out if your car is VLSD equipped or not. takes 5 mins toj ack it up and check. less then taht but by the time you pull out the jack and put blocks on the front adn then put everything back, it will have been about 5 mins
Aaron
Pink GodziRa
Old 07-17-2003, 04:18 PM   #11
driftingpanda
driftingpanda's Avatar
Trader Rating: (24)
driftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond repute
Feedback Score: 24 reviews
Send a message via AIM to driftingpanda
well, i guess you could find a parking lot, slowly accelerate in first gear with the steering fully left or right. increase throttle to the max, and you should end up in one of the three possible senarios:
1) inside tire spins in a smokey burn, car continues in the same circle.
2) both tires spin, car does a quick flip 180.
3) car accelerates and plows foward in yummy understeer.
senario 1 means it's an open diff, senario 2 means you have an lsd, senario 3 means you have to repeat the experiment again with quicker throttle increment. hope that helps... good luck!
-danny
PM me about limited edition Pink GodziRa Sticker packages!
driftingpanda is offline   Reply With Quote
