Old 07-14-2003, 11:36 AM   #1
Tbizz
Tbizz is an unknown quantity at this point
Urgent Headlamp question.
Im getting my car inspected tomorrow and my high beam on the right side doesnt work. I figured the bulbs' high beam element was busted so I bought a new light and found the same problem. I hope the problem is as simple as a broken fuse, can anyone help me on this matter??? Thanks
Sorry for posting on 2 forums
Tbizz is offline   Reply With Quote
Old 07-14-2003, 11:38 AM   #2
Dousan_PG
Dousan_PG's Avatar
why dont u examine your fuses?
then if they are ok, check all your wiring. maybe something is crimped/cut somewhere.
Aaron
Pink GodziRa
Old 07-14-2003, 11:47 AM   #3
uiuc240
uiuc240's Avatar
Be sure to check the electrical connector itself. It may be corroded and not making a good connection. Time to by a voltage tester with a continuity check on it.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
Old 07-14-2003, 11:50 AM   #4
Tbizz
ITs not any fuses...I checked them out. Is there a relay of some kind that would make something like this happen?
Old 07-14-2003, 11:52 AM   #5
Tbizz
I looked at the connection and it seemed fine when I installed the Bosch's, which was today. The low beam works fine on both sides its just the highbeam on the right side that wont turn on, while the left one works fine.
Old 07-14-2003, 12:39 PM   #6
Tbizz
I gotta track it back, its nothing simple...thanks for your help
