Old 07-16-2003, 03:39 AM   #1
Fibercus
Fibercus is on a distinguished road
Send a message via AIM to Fibercus
S14 Zenki SR - S14 zenki chassis wiring question
Should I need to tap one of the existing wires for +12v power supply on the F4 - M63 (Sr / ka underdash) Harnesses? specifically for the IACV-AAC and FICD
After I finished wiring it up, I went thru every sensor under the hood (associated with sr) and ran the testwith voltmeter using the FSM to tested them for power / function. Besides lengthening of the few wires, is this all that is needed to run the motor fine? I havent started the AC wiring nor have I attached power steering yet. First wiring project, and just wanted to hear what others thought, and if Im coming close to completion.
EDIT: going without AC for now
Fibercus is offline   Reply With Quote
Old 07-16-2003, 11:06 AM   #2
aeontony
aeontony is an unknown quantity at this point
Hi Fibercus,
The car should start without those two I believe..but I went through the idle valves with a voltimeter too, and tested them according to the FSM. I hooked them up according to how I thought they should be hooked up, but they weren't getting power. I then just hooked it up to a 12V source in one of the remaining ununsed wires. The car did start but because the timing was off we destroyed the pistons/got no compression. Pretty scary..
S14.5 for sale. Must move on with life...=(
http://www.zilvia.net/f/showthread.php?t=56822
Au no wa wakare no hajime...
aeontony is offline   Reply With Quote
Old 07-16-2003, 12:07 PM   #3
Fibercus
Whoa your scaring me. I got the car to idle pretty good, and I set the timing Via the FSM. I just wasnt sure if other were using other sources for 12v in the M63 harness. I already set the timing per the FSM also, am I lucky or is it normal for the SR to purr like a kitten right after its wired up?
hehe
