Old 07-16-2003, 04:57 PM   #1
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
need brake help tonight!
i want to upgrade to 300zx brakes but i can't afford it nor do i need it right now. but i do need new rear brake pads. i was just going to replace the rears with cheap pads from autozone until i can afford nice pads, calipers, rotors all aound and a master cylinder.
well, as luck would have it, as i was finishing up putting in the second set of pads, the caliper sprung a leak. i wasn't planning on upgrading to 300zx rears but i did want to upgrade the rears somehow. i heard that the jdm S14 rear calipers had a bigger piston (as well as 300zx fronts, but that's not important) so i was thinking of doing that.
time for the questions. should i just fix the caliper and go on my way, or should i upgrade the rears while i'm in there? if i should upgrade them, is there something i could do by tomorrow? like S14 w/ABS calipers or something? is the upgrade really worth the time, or should i just get new calipers since the parking brake arms are virtually frozen anyway? i don't want to spend my time rebuilding the caliper if i will just replace it in a month anyway.
does anybody know the piston size of the rear calipers? for S13, S14? fronts too if you can. also the piston size of 300zx fronts
thanks
cdlong is offline   Reply With Quote
