Old 05-07-2009, 10:17 PM   #601
ctnewman
ctnewman's Avatar
ctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of light
Send a message via AIM to ctnewman
Rhino-lined the floor... looks ILL
RB26DETT BMW E30 BUILD:
onyxsyndicate.com/newman/e30gtr/e30gtr_00.html
ctnewman is offline   Reply With Quote
Old 05-14-2009, 07:19 AM   #602
ctnewman
ctnewman's Avatar
Updated the site, but no new info...
E30GTR-PAINTING ENGINE BAY
AND
E30GTR-INTERIOR PAINTING
Old 05-14-2009, 07:36 PM   #603
PoorMans180SX
PoorMans180SX's Avatar
I totally forgot about this thread. Glad to see you're still going!
Subscribed.
Old 05-14-2009, 10:29 PM   #604
ctnewman
ctnewman's Avatar
Installed Poly control arm bushings (HUGE PAIN) and installed the front subframe, Ireland engineering swaybar + links, and steering rack.
Old 05-16-2009, 06:59 PM   #605
ctnewman
ctnewman's Avatar
Assembled the rear subframe. Pressing in the new poly bushings wasn't too difficult, all the parts were nicely powder coated...
That in itself created a little bit of a problem. A long time ago I had the rear subframe powdercoated. Then I remembered that I had purchased the Ireland Engineering camber kit.
This was a weld on kit with eccentric bolts that you rotate to change camber (inside bushing) and toe (outside bushing). Since I had to weld on the subframe and powdercoat again, I had to strip off all the old powdercoat. That was NOT easy. 3 trips through the automatic blaster, a belt sander, hand sanding and manual blasting later, I was able to weld and re-coat the part.
Welding the parts on was pretty easy, I had to do some extra fabricating, though, because the camber adjusters weren't all that well designed.
Here is a shot of the subframe assembled:
And a close-up of the camber adjusters. Basically the channel portion that the eccentric bolt rides in welds onto the subframe, then you slot the existing holes. Turning the bolt allows the bushing to ride up and down (foreground, camber) and forward and backward (background, toe)
Then I painted the rear dif. It took so fucking long to clean it... Like 4 hours. Just adding to the rainbow of colors! I used duplicolor 500 degree engine block paint to the dif. I used the some very aggressive stripper/degreaser to clean it.
A few shots of that:
Next, I installed the Ireland Engineering rear swaybar. The factory swaybar uses only one bolt and a tab to hold it on. The Ireland mounts use that one bolt, and then require the drilling of 2 more holes into the trunk then a backing plate. Much much stronger.
I didn't install the end links yet, because I'm not sure if their going to be in the way while installing the dif.
While the paint was drying I installed the subframe... alone. Kind of a pain in the ass to do alone, but it's done. I was worried that the subframe was going to be slightly warped from the automatic blaster, but it fit in fine. Finally something going right! I really need to re-spray the wheel wells.
Tomorrow I am probably going to rhinoliner the trunk and clean the transmission for installation...
Old 05-16-2009, 07:09 PM   #606
allntrlundrgrnd
allntrlundrgrnd's Avatar
damn never saw this build, very interesting. nice work nontheless!
scribe'd
Old 05-16-2009, 09:58 PM   #607
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
your colors are the colors of ireland! (cept no white yet)
(and minus the black and blue)
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 05-16-2009, 10:11 PM   #608
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
sick work man two thumbs up
Old 05-18-2009, 10:37 PM   #609
ctnewman
ctnewman's Avatar
installed rear wheel bearings tonight...
I just looked at page one of this thread and my head nearly exploded... anyway, hope to have this driving this year...
Old 05-19-2009, 02:06 PM   #610
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
why'd your head nearly explode? lol
Review Thread
bardabe is offline   Reply With Quote
Old 05-19-2009, 02:12 PM   #611
ctnewman
ctnewman's Avatar
There were a few highlights:
Originally Posted by ctnewman View Post
The idea is to build this car, paint it, toss on some fender flares and wide rotas, then drive it to the carlisle car show and toss a FS sign on it. I got the motor for a little over 3000 bucks, so i don't think i can't make profit on the car.
This is my tentative plan for construction:
Strip Body
Mount Engine
Build Exhaust and IC plumbing
New brake booster or remote mount
Build/buy driveshaft
Remove engine and all components. Strip to roller.
Shave firewall and enginebay.
Body work, paint, wheels
Paint engine covers, replace timing belt, thermostat and water pump
Reinstall engine and all plumbing
Rewire front half of car. Gauges?
Install race buckets. Possible bolt in cage.
Tune.
Old 05-20-2009, 11:43 PM   #612
ctnewman
ctnewman's Avatar
So here's what I did the past couple of days:
Installed new front hubs, ireland engineering stage 3 springs, bilstein sport struts and new OEM strut mounts. Everything is tight and new.
Also did the rear wheel bearings, with new OEM backing plate (required to hold the ebrake components)
Then I por15'd the trunk area. I am going to put rhinoliner over the top of this when it's dry. I like the protection that POR15 gives, but like the finish of the rhinoliner. So this is the best of both worlds.
I am going to paint the cage some zany color, only in the trunk. Thoughts?
Once that is all done, I'll install these new bilstein shock setups (with new upper mounts), along with ireland springs and M3 perches.
Next I snapped some pics of some of the parts I have laying around for this thing:
FPR, fuel filter, catch can, fittings for 044 pump, injectors, water pump, AEM serial gauge, AEM EMS, Tial 35mm WG and tial 50MM BOV.
And some more stuff:
Momo 300mm wheel, turbo timer (for ricers, prob won't install), 4 greddy warning gauges (I think I have 2 more somehere), AEM UEGO controller, Corbeau Harnesses (rest of harness not pictured)
Lastly, took some long overdue pics of my wheels. The FIT, thank god... Checked em out today... I'll need t buy rubber soon.
Old 05-21-2009, 07:43 PM   #613
ctnewman
ctnewman's Avatar
Threw the wheels on to see what tires would fit. These tires are going to be REALLY close... I don't have the fender here, so I had to kind of wing it, but I ordered the narrower of the two that I thought would fit. They're pretty cheap, so I can always upsize...
This is what I got...
Old 05-21-2009, 07:44 PM   #614
steve shadows
steve shadows's Avatar
Very cool build !
Like Me on FaceBook !
Old 05-21-2009, 08:28 PM   #615
hopeless.s13
hopeless.s13's Avatar
hopeless.s13 is an unknown quantity at this point
damn this is going to turn out way nice.
hopeless.s13 is offline   Reply With Quote
Old 05-22-2009, 05:52 AM   #616
opponheimer
Man, you should not use that eBay catch can.... build your own!!
Old 05-22-2009, 07:33 AM   #617
ctnewman
ctnewman's Avatar
Haha, I bought it when my subaru had a cracked piston and it was blowing tons and tons of oil out of the PCV valve. Lol. IDK If i will put it on or not...
Old 05-22-2009, 07:41 AM   #618
gsxr141
gsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymore
please finish the car so i can have a new background for my computer.
gsxr141 is offline   Reply With Quote
Old 05-22-2009, 07:48 AM   #619
ctnewman
ctnewman's Avatar
Oh yeah, also forgot to mention that I scooped up a set of these for the front and rear:
Old 05-27-2009, 06:31 AM   #620
ctnewman
ctnewman's Avatar
Tire porn:
Old 05-28-2009, 12:51 PM   #621
ctnewman
ctnewman's Avatar
Well the build is getting even more epic...
I pulled the head off to check the bores.
They're fucked up.
Ordered:
Wiseco 87mm Pistons
Eagle Rods
N1 Oil Pump
Jun Oil Pump Drive Collar
Cometic 87mm Head gasket
OEM Gasket kit
ARP head studs
Goddamnit.
Old 05-28-2009, 01:05 PM   #622
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
They're fucked up.
Ordered:
Wiseco 87mm Pistons
Eagle Rods
N1 Oil Pump
OEM Gasket kit
ARP head studs
Goddamnit.
Sorry to hear that man. Wouldn't be an RB if shit didn't go wrong.
Ask me how I know.
Neejay is offline   Reply With Quote
Old 05-28-2009, 01:07 PM   #623
ctnewman
ctnewman's Avatar
Ask me how I know.
Heh, I guess.
My old RB240 wound up being a similar clusterfuck.
Old 05-28-2009, 01:11 PM   #624
GSXRJJordan
GSXRJJordan's Avatar
Lol damn Newman... that's wild. Money pit to the maxxxxxxxxxxxxxxxxx.
You're going to drive this car, and love it. Know how I know? Because if you don't absolutely love it, or get a huuuuuge offer on it the first week, you'll probably off yourself lol - and that's just not right.
Old 05-28-2009, 01:14 PM   #625
ctnewman
ctnewman's Avatar
Well it fucking better be awesome.
Old 05-28-2009, 02:30 PM   #626
Bushido
Bushido's Avatar
i like this build.
but i'm not so sure about your choice in color scheme...
Old 05-28-2009, 02:33 PM   #627
ctnewman
ctnewman's Avatar
Everyone keeps saying that. You guys have no vision!
From the outside it will be green and black with gold wheels. If the hood is open, you'll see one more color, purple.
The rainbow of other colors is all hidden. Sheesh.
Old 05-28-2009, 02:36 PM   #628
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
dude i love that im not the only one who likes to have wide tires to match my wheels. 205 on an 11.5 width wheel is a freaking waste of wheel.
thanks for doing it right
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 05-28-2009, 02:37 PM   #629
ctnewman
ctnewman's Avatar
Fuck yeah.
Stretched tires are for fggts.
Old 05-28-2009, 02:38 PM   #630
bardabe
bardabe's Avatar
I LIKE THE BUILD NEWMAN! haha, shit wish i was balling out of control to build something like that. I'd prolly do something really stupid, lol
Review Thread
