Old 05-30-2009, 01:55 PM   #1
weshole
weshole's Avatar
weshole is an unknown quantity at this point
SR Help diagnosing engine woes
It started a few days ago. Noticed a ticking from the top of engine. Definitely sounds like a lifter. Have not been able to pinpoint which one. Figured I need to replace the lifters or at the very least remove them and pump them up. Then while driving, it felt like there was something restricting it under acceleration and sometimes would come out of it and pull just fine. Now, (every time) under full hard boost it pops, cracks, and backfires. A At part throttle it seem to be fine. It idles and starts up just fine as well. ANY IDEAS where I should start? Car is a 92 s13 with a redtop sr. t28 @ 10psi, starion fmic, 3" turbo back.
weshole is offline   Reply With Quote
Old 05-30-2009, 02:11 PM   #2
s14_mike
s14_mike will become famous soon enoughs14_mike will become famous soon enoughs14_mike will become famous soon enoughs14_mike will become famous soon enoughs14_mike will become famous soon enough
Does the ticking happen on cold start up and then go away after the engine idles for a few minutes? or is it constantly there?
s14_mike is offline   Reply With Quote
Old 05-30-2009, 02:18 PM   #3
RACETUNE
RACETUNE's Avatar
RACETUNE is on a distinguished road
Send a message via AIM to RACETUNE
What is your oil pressure?
-Garage BOSO-
-Racetune Engineering-
RACETUNE is offline   Reply With Quote
Old 05-30-2009, 02:57 PM   #4
weshole
weshole's Avatar
Found it guys. One of the spark plugs was missing the ground electrode. Seems to me that the spark plug is a little on the warm side for heat range for what Im running for boost. You guys tell me. its an NGK iridium BKR5EIX-11. I figured I should be running 6's at 10psi. Waht do you guys think? I got the car like this but there was 1 spare plug in the center counsel so that has me thinkin this has happened before.
Old 05-30-2009, 03:42 PM   #5
s14_mike
If you're gonna change one just change them all. If i can remember correctly I'm using BKR7E-11 and so far so good.
Old 05-30-2009, 03:50 PM   #6
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
i use cheap ass copper plugs because i foul out iridiums, they work perfectly fine
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 05-30-2009, 06:33 PM   #7
weshole
weshole's Avatar
I def plan on it.
