Old 06-02-2009, 07:34 PM   #1
bkfill
bkfill is an unknown quantity at this point
Z31 BMC Brake Master Cylinder going in a S14
I bought a rebuilt 1988 Z31 300zx non-turbo BMC from Autozone cost about 85$ and I can get 25$ back if I trade my old one in. (lifetime warranty)
I went with the Z31 nonturbo cause its got the highest split point to the rear
I have Z32 fronts only and stock S14 Rear
And I hope they gave me the right one
BM-44 NISSAN JAPAN NABCO
15/16 F F R (I'm guessing F is front and R is rear? someone please confirm this)
H23 32F20
2 diffrent seals
TOKICO H28 JAPAN
ERC 37 463 4 USA
Has the flair fitting
From what I read I can use my reservoir from my S14 BMC
How do you take off the reservoir?
And witch stock S14 lines are front and rear?
Thank you!
if it aint broken, fix it(95 240/96 sr20)
bkfill is offline   Reply With Quote
Old 06-02-2009, 07:38 PM   #2
slider2828
slider2828's Avatar
5they are i used them. they feel great
Turn and Burn!
Old 06-02-2009, 08:35 PM   #3
MADE
MADE's Avatar
MADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant future
The Definitive 300ZX Brake Swap!
Note: Doriftomodachi from Zilvia.net discovered that is possible to swap the fluid reservoir from the original master cylinder. Swapping the reservoir allows you to use the original fluid level wiring without having to splice wiring.
Hope this helps I didnt try or verify the info just looked into it awhile back.
MADE is offline   Reply With Quote
Old 06-02-2009, 08:46 PM   #4
devnull
devnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymore
The Definitive 300ZX brake swap covers Z32 brakes on S13 and S14.
The OP is talking about a Z31 BMC.
devnull is offline   Reply With Quote
Old 06-02-2009, 08:58 PM   #5
MADE
MADE's Avatar
.................... nvm
Old 06-03-2009, 08:02 AM   #6
Ali 556
Ali 556 is a well-known jackass
IT"S THE SAME DAMN THING
Damn guys,
OP F for front right and left and R for rear....
On s14 BMC the front two lines (infront of the plastic thingy) is for front....the bottem one is for rear
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 06-03-2009, 08:05 AM   #7
murda-c
murda-c's Avatar
The reservoir pops off if you pull it.
