Old 07-19-2003, 02:14 PM   #1
Carson
Carson is an unknown quantity at this point
idle on sr
is there any way to adjust the idle on a red top sr20? I idle at about 1100, and I want it lower; or is this a good idle speed?
Carson is offline   Reply With Quote
Old 07-19-2003, 02:43 PM   #2
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
the idle control valve is adjusted by a screw that can be accessed between the intake runners on the left hand side of the engine. it's a plastic screw...look for it. loosen to raise idle, tighten to lower it. there's more to it than that though...search.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 07-19-2003, 03:09 PM   #3
srpowereds14
srpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to behold
Send a message via AIM to srpowereds14
Plastic??? mine is metal... well turn it clockwise to lower the idle its in between the intake mani runners in the middle big screw.
srpowereds14 is offline   Reply With Quote
Old 07-19-2003, 06:33 PM   #4
Fibercus
Fibercus is on a distinguished road
Send a message via AIM to Fibercus
Go thru the set timing process, verify the timing is correct... IACValve would be a last resort wouldnt it? Becuase you also have the throttle body adjustment
Fibercus is offline   Reply With Quote
Old 07-20-2003, 12:01 AM   #5
uiuc240
uiuc240's Avatar
timing, yes.
but the IACV is the proper method for setting idle. the throttle body should be CLOSED at idle. that's the whole point of the IACV...it takes air and routes it AROUND the throttle plate.
Eric
2002 Mazda Protege5
Old 07-20-2003, 12:45 AM   #6
Fibercus
Originally posted by uiuc240
timing, yes.
Eric
Well, his idle is above the target. TB should be closed, thats why im saying to check it out... maybe its open some *shrug*
Old 07-20-2003, 02:02 AM   #7
uiuc240
uiuc240's Avatar
word.
but my $5 just says the IACV needs some tightening.
E
Old 07-20-2003, 08:11 AM   #8
Cheng
Cheng's Avatar
Cheng is an unknown quantity at this point
Yea, Mine is at about 900-1200 majority of the time its a 900...can any help me out here that why it would variey. Timing everything is ok...But, hey when you mess with the throttle position don't you mess up the timing as well?
90' 240sx fastback
Mods:
Sr20DET:
(BLITZ: FM/IC, BOV, DOWNPIPE, INTAKE)
(5zigen Fireball 3" Exhaust)
(Bee R testpipe)
(Walbro Fuel Pump)
Cheng is offline   Reply With Quote
