Old 06-07-2009, 05:52 AM   #1
fwuffy squirrel
Trader Rating: (26)
fwuffy squirrel is a jewel in the roughfwuffy squirrel is a jewel in the roughfwuffy squirrel is a jewel in the roughfwuffy squirrel is a jewel in the roughfwuffy squirrel is a jewel in the roughfwuffy squirrel is a jewel in the roughfwuffy squirrel is a jewel in the rough
Feedback Score: 26 reviews
Send a message via AIM to fwuffy squirrel
Grounding question
Okay so I read up on grounding kits and ever found most of the answers I needed, but I always seem to mess something up really badly and would like some idiot proof advice.
I have my battery relocated to the back and I just purchased an NRG ground kit (I know you could make your own, but I got it for a good price). Anyway I have all the cables and it feels like a shame to waste the circular part that is supposed to connect to the negative terminal.
This is a diagram I found.
Is there any way I could use the circular part on my negative terminal without having to make super long wires?
And do I even need to use the terminal? Could I just use the basic grounding point that exists where the battery used to be?
Lastly, would connecting the wires to the main engine points then all to the firewall for a ground work without giving me ground loop problems? If not, should I just find different grounds for each connection?
Thanks for all the help guys.
Originally Posted by dreamin240sx;
sounds like u have a bad case of "i have no idea what i'm doing"
fwuffy squirrel is offline   Reply With Quote
Old 06-07-2009, 12:21 PM   #2
oni jake
oni jake is an unknown quantity at this point
your post is a bit confusing. Grounding kits are used to balance the residual voltage from the engine to the frame (or I.E. your battery). As much as people would love to tell you, there isn't a %100 right way to put up a grounding it. Just make sure you aren't connecting a straight positive wire to the frame.
Since your battery is relocated into the trunk you can ground your engine to the frame and it will be safe. But as I said, just don't do something stupid like connect a ground wire to the positive 00 gauge wire on the starter. So instead of wiring everything back to the ground of your battery, just wire it to the closest part of the frame, fender, firewall, etc. as you can.
oni jake is offline   Reply With Quote
Old 06-07-2009, 11:21 PM   #3
slider2828
slider2828's Avatar
There should be a post or 2 because I wrote them.
Those points are junk.
Tranny, Head, Block, Intake Manifold, Alternator, Chassis, and coil pack ground are the best.
I just did a relocation. The negatives can just tie all into one point in the chassis and the battery neg grounds to like the chassis and done...
Turn and Burn!
Old 06-08-2009, 09:18 AM   #4
fwuffy squirrel
Trader Rating: (26)
=D Thanks a lot. That was exactly what I needed. I did them yesterday and luckily got all of those except for the tranny. I will probably go back and do that today.
Old 06-08-2009, 02:58 PM   #5
slider2828
slider2828's Avatar
Great! Sell me your stuff! You have some nice for sale stuff.... but sigh... can't afford... damn engagement ring sigh.....
Turn and Burn!
Old 06-08-2009, 03:06 PM   #6
94_240sx
94_240sx is on a distinguished road
Ground is pretty good on 240, so you won't feel much difference.
94_240sx is offline   Reply With Quote
Old 06-08-2009, 04:46 PM   #7
slider2828
slider2828's Avatar
^^^ Wtf you talking about... Ground is shit especially on the 89-93 S13's.... They are horrible. I with upgraded motors, the alternator is just barely strong enough to power the car.... There is amperage drops all the time...
Turn and Burn!
Old 06-08-2009, 06:09 PM   #8
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Wait.. What??
Uh huh... Go look at your grounds. First off your engine ground is like 10 ga. THAT small has heck! Doing any upgrade is good.
Oh you'll feel a difference.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 06-08-2009, 08:34 PM   #9
MrChow
MrChow's Avatar
Oh to OP to be honest. A lot of lil 8 ga don't work has well has one big 4ga. If I get a chance I'll take a pic of my grounds.
The 2 main ground that need to be redo is from the Battery - to the chassis and the Engine to the chassis.
