Old 06-07-2009, 11:46 PM   #1
weshole
weshole's Avatar
weshole is an unknown quantity at this point
I am trying to find a definitive answer.
I have an SR swapped S13. It is equipped with a #63 ecu and no tuning software at all over and above this. The issue I really have is in 5th gear and that gear only, it has a rev limit of 5300 rpm. I have spent countless hours reading on this and have not come up with any answers as to why this is. Read all the transmission sensor threads only to realize that the SR trannies dont have all the sensors attached to it that the Ka trans does. Does znyone have an answer as to why this is happening?
weshole is offline   Reply With Quote
Old 06-07-2009, 11:55 PM   #2
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
it's a stock speed limiter from nissan
R@ddy is offline   Reply With Quote
Old 06-08-2009, 12:24 AM   #3
I LUV MY S13
I LUV MY S13's Avatar
dosconnect 5th gear sensor harness
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 06-08-2009, 12:29 AM   #4
weshole
weshole's Avatar
There is no 5th gear sensor on my trans. only vss, neutral safety switch, and reverse light switch.
Old 06-08-2009, 12:33 AM   #5
I LUV MY S13
wat codes does ur ecu throw out?
-Jorge
Old 06-08-2009, 01:52 AM   #6
weshole
weshole's Avatar
No codes. Everything operates in tip top shape. I am nearly as fast in 4th as I am in 5th gear is all.
Old 06-08-2009, 02:04 AM   #7
Sileighty_85
Sileighty_85's Avatar
are you hitting 120mph? If so then you are hitting the speed cut
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-08-2009, 02:29 AM   #8
weshole
weshole's Avatar
Well, the speedo only goes up to 110mph and I am by far, surpassing that. With the J30 gearset/diff, I am assuming its a tad over 120mph. probably by a few mph.
Old 06-08-2009, 03:09 AM   #9
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
thats the stock governor
i forget how to get rid of it...with a KA i know you just switch to a auto ECU and your good to go, but with SR I think you have to get a tune or some kinda chip.
DataXUnknown is offline   Reply With Quote
Old 06-08-2009, 07:19 AM   #10
weshole
weshole's Avatar
That's what I was coming up with as well. I was looking for reinforcement on that.
Old 06-08-2009, 07:40 AM   #11
murda-c
murda-c's Avatar
looks like somebody's getting a power fc
Old 06-08-2009, 07:42 AM   #12
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
HKS USA FCD (Fuel Cut Defencer)
unionautoclub.com
dori_sil8t is offline   Reply With Quote
Old 06-08-2009, 11:38 AM   #13
weshole
weshole's Avatar
Thats's one option that has crossed my mind.
Originally Posted by dori_sil8t View Post
Don't think that will help my cause.
Old 06-08-2009, 10:39 PM   #14
weshole
weshole's Avatar
So what is giving the signal to the ecu that im in 5th gear when there's no 5th gear sensor? That makes absolutely no sense. It doesnt rev limit in any other gear. unless it does sense off the speed sensor itself. I havent gone that fast in 4th gear to eliminate that from the eqation. I didnt feel the need to rev the engine THAT high.
