Old 06-08-2009, 05:19 PM   #1
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
34mm rad hose adaptor npt fitting Q
I got 2 of those rad hose adaptors for my breather tank setup. However the 1/8th npt fittings arent threading in all the way - maybe 1/2 if even. Its a very very tight fit, as if im crossthreading, however ive tried about 4 different fitting styles and all are the same.
Isnt the NPT fittings supposed to be a looser fit, because you have to use teflon tape? I couldnt even use thread locker because the fit is so tight. I even snapped a fitting half way in, which required me to order another 34mm rad hose adaptor.
Bigsyke is offline   Reply With Quote
Old 06-08-2009, 06:58 PM   #2
orion::S14
orion::S14's Avatar
No...NPT is a tight fight, it's tapered.
It get's tighter as you turn it...so there's no need for teflon tape or anything.
- Brian
www.KA24DEvelopment.com
Old 06-08-2009, 07:16 PM   #3
Bigsyke
Bigsyke's Avatar
Sweet, is there a general torque setting for it? I think I snapped the other fitting at about 15lbs.
Old 06-08-2009, 08:05 PM   #4
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Hand tight should be more than enough.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 06-08-2009, 10:20 PM   #5
j87w
j87w is an unknown quantity at this point
- Brian
What do you use teflon tape on? Teflon tape (PTFE) is designed for pipe thread (NPT) . You can get away without using teflon tape on pipe but I have had much better luck when using teflon to eliminate leaks. Thread seal tape - Wikipedia, the free encyclopedia
Also when tapping NPT threads the general rule I have always gone by is to run the tap in 2/3 way. So you should never run up the fitting until its out of threads.
j87w is offline   Reply With Quote
Old 06-09-2009, 08:38 AM   #6
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
what hose adapter are u using? greddy sard? and are u using a provided fitting or did u just get a NPT fitting?
if you are using a Jap brand (greddy sard etc) then the hole is not NPT it BSPT or PT, they are a little different from NPT.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 06-09-2009, 02:40 PM   #7
Bigsyke
Bigsyke's Avatar
I got one off ebay for $15
34mm Water temp Gauge Radiator Hose Sensor Adaptor:eBay Motors (item 290305177970 end time Jun-21-09 21:41:50 PDT)
