Old 06-14-2009, 09:03 AM   #1
Kaizen.
Kaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymore
Angry KA-T Issues!!!!
LOCK PLEASE.
Problem solved.
Kaizen. is offline   Reply With Quote
Old 06-14-2009, 09:48 AM   #2
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
could be your crappy emance tune...
SilviaSR20DET is offline   Reply With Quote
Old 06-14-2009, 10:05 AM   #3
LFOabuse
LFOabuse's Avatar
LFOabuse is making a name for him/her selfLFOabuse is making a name for him/her self
Sounds like your MAF is not wired correctly. You have the same symptomology of a KA with the MAF unplugged. AKA "limp mode".
Unplug your MAF then start up and see if anything changes, if it doesn't there's our problem.
LFOabuse is offline   Reply With Quote
Old 06-14-2009, 10:07 AM   #4
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
shitty maf
unionautoclub.com
dori_sil8t is offline   Reply With Quote
Old 06-14-2009, 10:33 AM   #5
Steveohoes
Steveohoes's Avatar
Steveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymore
Try cleaning out your maf with some sort of spray.
Steveohoes is offline   Reply With Quote
Old 06-14-2009, 02:30 PM   #6
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
run stock ecu and stock maf see what happens.
get a fpr and gauge on it and see whats up. check timing!.
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 06-14-2009, 02:32 PM   #7
hotlavaflow
hotlavaflow's Avatar
hotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to behold
Send a message via Yahoo to hotlavaflow
co-sign on the MAF
BTW
I have an Emance tune T3/T4 740cc and it runs perfect.
hotlavaflow is offline   Reply With Quote
Old 06-14-2009, 02:32 PM   #8
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
I would double check your maf wiring.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 06-14-2009, 02:43 PM   #9
Ktown_drifter
Ktown_drifter's Avatar
Ktown_drifter is an unknown quantity at this point
agreed looks like maf limp mode
613driftwerks.ca
Ktown_drifter is offline   Reply With Quote
Old 06-14-2009, 05:59 PM   #10
Kaizen.
www.ka-t.org :: View topic - z32 maf wiring
Is the above correct order? I got four wires comin out of the pigtail z32
Old 06-15-2009, 12:32 AM   #11
sunnys14
sunnys14's Avatar
sunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nice
Like, I told you, its the maf/maf wiring.
One of the wires on the z32 maf will be grounded to the chassis.
sunnys14 is offline   Reply With Quote
Old 06-15-2009, 05:18 AM   #12
Kaizen.
Did it, its a no go. Ground it, followed diagram, I'll re rewire again tomoro. Also cleaned the maf today too.
Idles at 1400 when warmed up, 17-1800 when cold. Bogs around 25-3k when driving, can't even get pass 3500 after that, can't drive it.
Old 06-15-2009, 05:11 PM   #13
Kaizen.
So when I took the MAF sensor harness out, the car ran the same exact way as if it was in there, does that mean the maf sensors out?
Old 06-15-2009, 07:38 PM   #14
240blitz
240blitz's Avatar
240blitz is an unknown quantity at this point
check the duaghter board on the ecu to make sure its in right. Then rest the ecu by disconnecting the battery for 10-15 min. Sounds like the ecu might be running on safe mode. i have an emance ecu also with that set up and it did that at first also.
240blitz is offline   Reply With Quote
Old 06-15-2009, 09:42 PM   #15
Kaizen.
^^ Tried that, nothing changed. my friends about to come by with his 300z bouta slap his maf on and see whats up.
Old 06-15-2009, 09:45 PM   #16
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
im pretty sure thats what it is.
switch some wires around on your wiring.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 06-15-2009, 09:59 PM   #17
Killa_D
Killa_D's Avatar
Trader Rating: (39)
Killa_D can only hope to improve
Feedback Score: 39 reviews
try a different maf
Killa_D is offline   Reply With Quote
Old 06-15-2009, 11:49 PM   #18
Kaizen.
Switched wires around, just tried my friends maf sensor, still ran the same after. Im about to drive my car into a river!
Old 06-16-2009, 12:08 AM   #19
DoriSaruMark
DoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really nice
check for boost leaks on both sides of the throttle body. High idle can be due to a vaccum leak on the manifold side of the throttle body. Not being able to rev passed 3500 could be due to the fact that the maf is recieving incorrect readings due to a possible leak.
Good luck.
DoriSaruMark is offline   Reply With Quote
Old 06-16-2009, 12:20 AM   #20
dsc4130
dsc4130's Avatar
dsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nice
im confused
"emance tuned obd1 ecu (for 370cc, z32 maf, and t25)
obd1 to obd2 conversion harness"
why an obd1ecu on an obd 2 harness?
if you have a friend or happen to have an safc2 laying around, wire it up and see if the ecu is reading the MAF properly. if the safc fixes the probelm, means your ecu isnt reading
I <3 jdmhookup
dsc4130 is offline   Reply With Quote
Old 06-16-2009, 12:40 AM   #21
LFOabuse
LFOabuse's Avatar
Then it's the MAF or the wiring to it. If you tried a known working one that narrows it down. Try pulling the cable to the MAF on your buddies working car then start up and see if it has the same problems as yours, it will go into limp mode as well. Never heard of anything else on a KA causing limp mode, but...?
Vac and boost leaks can cause a lots of problems but you wouldn't be rev limited to 3k, plus you would have very erratic idle.
Old 06-16-2009, 06:33 PM   #22
Kaizen.
When I removed the maf off my friends Z, it wouldnt even run. When I used my friends maf, my car ran the same.
Old 06-17-2009, 12:53 AM   #23
Addicted2Kouki
have you tried your maf on his car?!
if that works... then its your wiring.. period.
only other possibility would be your ecu being fried or your chip isnt placed properly.
Old 06-17-2009, 08:43 AM   #24
Kaizen.
Yea, I did. His car ran the same as if his was in. Plus the guy that sold me ecu said it was running fine before he took it off.
This is the diagram I ran with http://jimwolftechnology.com/wolfpdf...%20NISSANS.PDF
Heres another thing, when I drove it in 5th doing 60, when I floor it, I hear the turbo spooling up but its not going anywhere.
Checked the spark plugs, stuupid black. Plus I filled her up and I went thru a quarter tank with only 20 miles! Stupid rich. =(
Old 06-17-2009, 09:54 AM   #25
SilviaSR20DET
knock sensor going bad?
Old 06-17-2009, 07:36 PM   #26
Addicted2Kouki
the ecu in limp mode will always be retardedly rich.
your maf wiring should be the culprit.
I still have to check out the link you posted
because I'm online with a phone
if you can, take out the chip and anything you can unplug with it.
plug it all back together.
Old 06-17-2009, 10:10 PM   #27
Kaizen.
So I checked the ecu for codes today and the light wouldn't blink. Scan tool couldn't read and connect with the ecu. Wiring to the maf is correct, I have a 91 ecu to a 97 harness.
Old 06-18-2009, 12:23 AM   #28
Addicted2Kouki
yeah, i dont think you can check for codes on an emance.
did you check the chip and unplug, etc like i said?
also, you cant completely rule out wiring.
first time i did my maf swap,
i followed the write up EXACTLY.
tripled checked the pictures and my car ran like yours.
swap 2 different wires and it ran perfect.
CONSIDERING YOUR SYMPTOMS,
it can only be....
-MAF WIRING
-ECU
-CONVERSION HARNESS ISNT RIGHT
btw. who made the conversion harness?
Old 06-18-2009, 05:46 AM   #29
Kaizen.
What do you mean by chip and unplug?
The conversion harness was purchased on here from another member. The harness looks super duper ghetto. I'll take pictures to show you.
What rpm does limp mode limit me to? I can rev up when I drive, just bogs like no tomorrow, plus it idles now at 1100. Im going to bring it to my friends shop on friday to have some people look at it. I'll switch the wire around again just to see tomorrow. I doubt its the wiring cuz I tried already. If anything I think its the ecu or the conversion harness.
I'll let you know how it goes, thanks for the help.
