Old 06-15-2009, 02:49 PM   #1
90240sr
90240sr is an unknown quantity at this point
KA Starter Install ?
So there are two bolts that hold on the negative and positive. The other two bolts hold in the starter and i hear are a pain to get to. Does anyone have any good advice on getting them out before i start. Also what are the torque specs when you tighten the new one on, i didn't see any in the FSM. Thank you
JFAB "BIGGEST GUNS WEST OF THE MISSISSIPPI"
90240sr is offline   Reply With Quote
Old 06-15-2009, 03:24 PM   #2
timlush
timlush's Avatar
timlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to behold
Send a message via AIM to timlush
The 2 wires are not pos and neg. One is 12v power, the other (small one) is the starter signal. Installation and removal is pretty straight forward. Make sure you disconnect the battery.
timlush is offline   Reply With Quote
Old 06-15-2009, 03:25 PM   #3
slider2828
slider2828's Avatar
Just use your judgement, its not really a big thing replacing the starter.... I thought it was just 2 bolts holding the starter to the tranny and thre were just starter wire, positive and negative running to it. But I could be wrong. Probably double wrenching it will get you good with torque.
Turn and Burn!
Old 06-15-2009, 03:31 PM   #4
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
use a 12mm wrench and touch one end of the bolt to the other something cool will happen
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 06-15-2009, 03:35 PM   #5
90240sr
timlush- thanks yeah its not negative and positive sorry. Their is one hard bolt i heard a swivel extension helps.
s13silvia123- hahah ill pass on that front.
Old 06-15-2009, 03:35 PM   #6
slider2828
slider2828's Avatar
^^^^ Don't do it lol!!! Bastard ahahhaha!!! That will for sure blow a fuse hahahaha!
REMOVE THE BATTERY battery with you do anything with electrical in your car.... I friend my ecu messing with the MAFS!!! But everyone has a first time! hahaha
Turn and Burn!
Old 06-15-2009, 05:42 PM   #7
yukon
yukon is an unknown quantity at this point
The starter is grounded simply by being in contact with the motor. Starter wont work if the interface is rusty.
yukon is offline   Reply With Quote
Old 06-15-2009, 08:00 PM   #8
s13silvia123
sorry man i needed a little laugh LOL
Old 06-15-2009, 08:20 PM   #9
The Chad
The Chad's Avatar
The Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really nice
To quote the Chilton Manual...ahem " 1st disconnect battery. 2nd remove starter. 3rd install new starter. Replace battery" I wish all installations were that easy.
But seriously, It's not bad. I've done a few on my past 240's. Just make sure you don't over tighten and strip out the starter where the bolts thread in...my shitty Chinese starter stripped pretty easily.
The Chad is offline   Reply With Quote
Old 06-15-2009, 08:39 PM   #10
wiggafly808
wiggafly808's Avatar
wiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to all
It helps to have a universal joint and an extension.. Other than that, disconnect the battery, take off the three or four bolts, and replace.
First time it took me maybe an hour, second time 20-30 mins
wiggafly808 is offline   Reply With Quote
Old 06-15-2009, 11:21 PM   #11
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
u dont wanna start without the right tools first.
i started mine and it took 1 whole day cuz i had to go buy tools in between.
it was a bitch getting to the bolts but it works out fine if you have the right tools for the job
lexus baby
5t341tH is offline   Reply With Quote
Old 06-17-2009, 02:01 PM   #12
90240sr
Got it done within an hour. Pretty easy except i was to impatient to let my engine cool down and burned my arm a little taking the top bolt off. lol
Old 06-17-2009, 05:19 PM   #13
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Easiest way, to get th starter off...crawl under the car...
CLICK HERE!!!
