Old 06-17-2009, 06:27 PM   #1
adam s
adam s's Avatar
adam s is an unknown quantity at this point
s13 1992 240sx No Idle/Dying while in Neutral
If I can get any help at all it would be amazing.
I have a 1992 240sx LE
160K
Here's whats happening:
Starting:
1. When ever I go to start the car, it cranks for about 20-30 seconds.
2. As soon as it starts getting gas, I have to press on the accelerator to keep it from dying again.
3. If I take my foot off the gas, it will die.
4. Hence no Idle.
Driving:
1. Car drives fine, maybe a little rough, however, as soon as I put it in neutral for a stop, coasting, w/e, it will die unless I force it to "idle" by revving the engine.
Some of the problems I noticed when i began to diagnose, and a little history:
1. Replaced a misfiring injector about a month before the problem.
2. Replacing corroded battery connectors as we speak.
3. Spark plug wires are 3 month old NGK blues (I know, I know...)
4. Spark plugs are black black.
5. Valve cover gasket and spark plug gaskets were replaced 5-6 months ago to fix oily exhaust smoke.
Thats all I know, when I got the car about 7 months ago it pretty much ran fine except valve cover.
Only things that came to mind for me were:
Alternator?
Battery? (no idea how old)
MAF?
IAC?
Any help would be greatly appreciated.
adam s is offline   Reply With Quote
Old 06-17-2009, 06:51 PM   #2
wings_s13
wings_s13 is an unknown quantity at this point
sounds like yourtimming is way off and your running really rich soo check that
wings_s13 is offline   Reply With Quote
Old 06-17-2009, 07:12 PM   #3
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
check for vac leaks.
I don't think it's timing...period
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 06-17-2009, 07:35 PM   #4
nrmskate
nrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura about
I think it could be timing.
Mine used to do that and it ended up being 2 degrees retarded.
I would check other stuff though.
TPS Voltage, MAF, IACV is clean, run intake cleaner through it, vac leaks, etc.
nrmskate is offline   Reply With Quote
Old 06-17-2009, 07:41 PM   #5
LFOabuse
LFOabuse's Avatar
LFOabuse is making a name for him/her selfLFOabuse is making a name for him/her self
^^ Agreed. There are a ton of vac lines under the intake manifold that are hard to reach or even see. Check em all.
LFOabuse is offline   Reply With Quote
Old 06-17-2009, 07:56 PM   #6
adam s
adam s's Avatar
Awesome will check those lines tomorrow, as well as do an oil change haha (the time has come).
Im pretty sure it isnt timing.
Replaced plugs and battery terminals, car still has no idle, however, the rough running has disappeared (plugs ffs..)
Oh and noticed that when the car does idle (very rarely and at 500ish rpm) I get black smoke from the exhaust, however as soon as I hit the exhaust I get white.
Old 06-18-2009, 12:18 AM   #7
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Sounds like a problem I had when my O2 sensor AND Water temp sensor for the ECU were both bad.
Old 06-18-2009, 12:21 AM   #8
wgJoY
wgJoY's Avatar
wgJoY is an unknown quantity at this point
Send a message via AIM to wgJoY
+1.
That is your best bet.
wgJoY is offline   Reply With Quote
Old 06-18-2009, 12:33 AM   #9
Addicted2Kouki
oh yeah, CTS. that could be it.
Old 06-18-2009, 12:59 AM   #10
I LUV MY S13
I LUV MY S13's Avatar
completely agree..also iacv or maf
-Jorge
I LUV MY S13 is offline   Reply With Quote
