Old 06-25-2009, 10:33 AM   #1
r-b-x
r-b-x is an unknown quantity at this point
uneven ride height in the rear: what's wrong with my car!!??
so my ride heights on the rear are uneven. they're off by an inch from side to side and haven't been able to determine why. used to think it was because my driveway was uneven. jacked up the car and measured coilover lengths and found them to be the same! even so, while it was up, i noticed the lower control arms' angles were different. 1 side was definitely higher than the other. i have 2 guesses: chassis is tweaked or axles being offset. axles being offset because the diff is asymmetrical and the axles are of different lengths. if so, i don't know when that happened... does anybody have other guesses at why my car's like this?
i already figured how i'm going to fix it: raising the lower side up. raise because the other side is maxed out and i can't lower adjust the lower bracket any more. don't really feel like adjusting the preload.
r-b-x is offline   Reply With Quote
Old 06-25-2009, 11:24 AM   #2
orion::S14
orion::S14's Avatar
Different springs? What coilovers?
Check the rates, they are typically listed on the spring.
- Brian
www.KA24DEvelopment.com
Old 06-25-2009, 11:28 AM   #3
ClarkBlaze
ClarkBlaze's Avatar
ClarkBlaze is an unknown quantity at this point
hes rite, the spring ratio could be different
ClarkBlaze is offline   Reply With Quote
Old 06-25-2009, 11:32 AM   #4
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
It could be that your preload in the rear is set differently. The right side has more preload than the left side.
It could also be that your front coilovers are way off. Maybe your front right coilover is a lot higher than your front left causing your whole car to lean to the left. The coilovers should be close to the same height side to side. Check both of those things.
karl wasabi is offline   Reply With Quote
Old 06-25-2009, 11:33 AM   #5
aznpoopy
aznpoopy's Avatar
just because the coilover heights are set the same does not mean the car will be even.
no car is weighted symmetrically right/left (or on all four corners). if it was, there'd be no reason for any car to be corner weighed.
in other words, adjust coilover height independently at each corner until the car sits the way you want it to. don't worry about keeping coilover height even, as that is meaningless anyway. i would only worry about keeping preload/droop even.
Old 06-25-2009, 01:35 PM   #6
superJoy
superJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of light
My car does this too, it's a little over 1 cm higher on the passenger side rear if the coils are adjusted to the same length
I think it's pretty common on S13, have heard about it before at least. It also makes the wheel fitment look off, since one side is higher.
The fix: lower that side whatever amount you think your car is off, and don't worry about it
superJoy is offline   Reply With Quote
Old 06-25-2009, 01:40 PM   #7
jdm_vert
jdm_vert is not welcome here anymorejdm_vert is not welcome here anymorejdm_vert is not welcome here anymorejdm_vert is not welcome here anymorejdm_vert is not welcome here anymorejdm_vert is not welcome here anymorejdm_vert is not welcome here anymorejdm_vert is not welcome here anymorejdm_vert is not welcome here anymorejdm_vert is not welcome here anymorejdm_vert is not welcome here anymore
its the gas tank -_- fill it up and it should level out
jdm_vert is offline   Reply With Quote
Old 06-25-2009, 08:46 PM   #8
r-b-x
it could be weight. but even when the car is jacked up, the angles of the lower control arms are different. the right side, the higher side, has the arm hanging lower. given that, it makes sense for that side to be higher. what i don't get is why that is...
goddamn old cars
Old 06-25-2009, 09:39 PM   #9
Souljahzs13
Trader Rating: (66)
Souljahzs13 is an unknown quantity at this point
Feedback Score: 66 reviews
You're not the only one with that problem, my whole passenger side is like that on maxed out coilovers.
Souljahzs13 is offline   Reply With Quote
Old 06-26-2009, 07:21 AM   #10
smelly240
smelly240's Avatar
most cars we put coilovers on are off a little side to side. as long as u preload the same - you should be good.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 06-26-2009, 07:24 AM   #11
Z33dori
Z33dori's Avatar
measure the car height
measure from the rocker panel corner in front of and behind the rear wheel, and then measure from the top of the fender to the ground.
Old 06-26-2009, 08:32 AM   #12
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
I had a broken sway bar end link that caused this, although it was in the front.
ryguy is offline   Reply With Quote
Old 06-26-2009, 11:35 AM   #13
smelly240
smelly240's Avatar
WTF - how did an endlink do that?
Old 06-27-2009, 12:13 AM   #14
ryguy
ryguy's Avatar
One of the endlinks broke and the sway bar only acted on one side. I was on mushy ass stock suspension at the time so I guess maybe that mattered, but one side was honestly an inch and a half lower than the other. I thought the suspension had broken.
Old 06-28-2009, 02:10 AM   #15
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
its seriously only an s13 problem..funny thing my car sits the same side as well..lmao
negrosx13 is offline   Reply With Quote
Old 06-28-2009, 08:46 AM   #16
g6civcx
g6civcx's Avatar
It can be weight distribution, suspension alignment, or coilover settings.
Clean out your car, then have the alignment checked. Then you can adjust your coilovers.
Old 06-28-2009, 12:48 PM   #17
Marc240
Marc240's Avatar
Marc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-known
Adjust the spring preload and you should be fine, then adjust the ride height again to were you preffer and it should even it out.
Marc240 is offline   Reply With Quote
