Old 07-10-2009, 03:04 PM   #1
s14canyoncity
s14canyoncity's Avatar
Trader Rating: (50)
s14canyoncity is an unknown quantity at this point
Feedback Score: 50 reviews
Keyless remote problem
so i've done alot off searchin on here and none of the post answered my question. i just bought a new keyless remote and wanted to program the b*tch. but the issue im having is step #5 im not getting any indication that the remote is programmed(hazard blinking.) HELP!!
i bought a Remocon RMC-105 from ebay...........
For OEM stock keyless entry systems 95 < (and above)
1.Get in & lock the doors
2.Insert the key into the ignition 6 times within 15 seconds (taking the key out all the way, then back in).
3.Hazard lights should flash
4.Put key back into the ignition & turn to run position but do not start.
5.Hit the lock button on the remote
6.Hazards should flash.
7.Pull key out and open the drivers door and then close it
8.It should be set
HALT!!!
Remember to do number 7! most people think it's programmed after they pull the key out. you have to unlock the doors, open the drivers door, then close it to be programmed correctly.
s14canyoncity is offline   Reply With Quote
Old 07-10-2009, 03:17 PM   #2
projectRDM
projectRDM's Avatar
So, are you offering a solution, or asking about a problem? Your title says problem, so which is it?
BTW, the FSM tells you all this. No need to rehash it.
FORMERLY R240NA
Old 07-10-2009, 05:58 PM   #3
s14canyoncity
Trader Rating: (50)
\the issue im having is step #5 im not getting any indication that the remote is programmed(hazard blinking.) HELP!!
