Old 07-29-2003, 04:11 PM   #1
super_hicas
super_hicas is an unknown quantity at this point
Koni Sport (yellow) Install Help
how do i install my KONI shocks with eibachs? they dont come with the mounts. its so weird. help!
super_hicas is offline   Reply With Quote
Old 07-29-2003, 04:26 PM   #2
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
1. Open the box
2. Unfold the instructions
3. Read
4. Take out old front strut assembly and disassemble
5. Clamp old strut in vise or other device for holding steady
6. Use hacksaw/angle grinder to cut off end of strut housing (about 1/2" up from where the shaft comes OUT of the housing...the instructions show exactly where to cut)
7. Take out the guts and drain the oil
8. Flip housing on end and drill hole for bolt (per KONI's instructions)
9. De-burr the freshly cut housing with sandpaper/Dremel
10. Insert new KONI
11. Bolt in from bottom
12. Slide rubber dust ring around the top (near the end of the housing by the shaft)
13. Reassemble strut with spring and the rest
14. Put it in your car
15. Repeat for other side
The rears are like any other shock.
OK. That was the pimpest writeup ever for KONI inserts. Someone archive this sh*t cuz I don't want to write it again.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 07-29-2003, 04:35 PM   #3
super_hicas
YOU ARE DA MAN! hope this shiet works. wish me luck.
Old 07-29-2003, 04:46 PM   #4
super_hicas
ill see if i can use your tips and take some pictures of the steps taken while i get work on it and maybe zilvia.net will post it up on the install help section. your tips and my pictures that is.
Old 07-29-2003, 08:00 PM   #5
uiuc240
uiuc240's Avatar
rock on. maybe more people will buy the konis then. so many of these p*ssies refuse to get the "good shocks" for fear that they won't be able to install them. props to you for taking the chance. the konis are 10x stronger than KYB and Tokico. you'll love them.
good luck! and take good pics! use the flash so it's not blurry.
Eric
Old 07-30-2003, 01:03 AM   #6
super_hicas
3.2 megapixels should be enough. wish me luck. i KNOW ill enjoy them!
Old 07-30-2003, 01:06 AM   #7
Johny5
Johny5's Avatar
They however aren't stronger than Tokico Illuminas, blues are childs play. Illuminas vs. Yellows on my g2 teg and Illuminas won with a softer spring (sprint) vs eibach. But yes it is a good writeup.
www.stewartleask.com
Johny5 is offline   Reply With Quote
Old 07-30-2003, 08:12 AM   #8
uiuc240
uiuc240's Avatar
Konis walk all over Tokico Illuminas. Talk to anyone who autocrosses or road races. Not only are Konis better in initial quality, but they are completely customizable and rebuildable by Koni.
Oh, and what do you mean by "won" on your car?
Eric
Old 07-30-2003, 10:00 AM   #9
super_hicas
uh oh... looks like i started a fight. :hammer:
Old 07-30-2003, 10:10 AM   #10
uiuc240
uiuc240's Avatar
hehe...no fight...Johny5 lost already
E
Old 07-30-2003, 10:21 AM   #11
super_hicas
and we have a winner! uiuc240
Old 07-30-2003, 12:20 PM   #12
DuffMan
DuffMan's Avatar
I'm pretty sure illuminas arent rebound/bump adjustable, and there are shock dyno charts that prove that illuminas adjustment range isnt even close to konis.
Old 07-30-2003, 12:30 PM   #13
uiuc240
uiuc240's Avatar
Scott,
I'd be interested in seeing this "proof" you've found...and something to remember is that Koni valves the shocks differently for every car. In my case, the Konis were valved specifically for use with my car/engine and Whiteline springs. Konis are not even really designed to be "adjusted"...although they advertise them like that If you talk to a Koni dealer, the real idea behind the adjustment is to stiffen them up as they wear. So far, I've had mine for over a year and they're just as stiff today.
But you're right...the Konis can go from rock solid to floppy in just a couple of turns. But they're not as easy to adjust in the rear...unlike the Tokicos.
In any case, I don't need to go back and forth about this. Opinions are like s...everyone's got one.
Eric
Old 07-30-2003, 01:13 PM   #14
DuffMan
DuffMan's Avatar
http://www.koni-na.com/civicdyno.pdf
Its for a civic so the valving is different than a 240, but I would assume adjustment range would be similar for a brand of shock across different cars.
EDIT fixed link
Ok now that I actually READ the thing, I see that Illuminas have a decent range and are stiffer than Konis. Doesnt necessarily mean they are better, but anyway, what I was thinking of was the AGX which you can see does not have a wide range of adjustment.
Old 07-31-2003, 03:47 PM   #15
super_hicas
i dont understand the rears. they dont look adjustable. how do i adjust it? it didnt even come with its own dial. only the fronts did.
Old 07-31-2003, 04:27 PM   #16
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
Rears are adjustable as per the directions. Provided yours did not come with any or you can't read words that don't glow, here it is:
Rear koni adjustment works best with a solidly mounted vice.
Lock end of piston in vice
Fully compress the shock (and I mean fully compress it)
While fully compressed rotation of the shock body adjusts the damping (rebound only). Clockwise is firm, CC is softer IIRC.
The shock must remained fully compressed while it is turned or the shock will not be adjusted. You should be able to feel when it engages/ disengages.
There is a huge difference between soft and firm so have no fear of being able to tell if it's been adjusted. On soft it should decompress easier than it compressed. On full stiff it's going to take a while.
Just like the fronts with the magin Koni knob, adjustment is 2 full turns lock to lock. The easiest way to determine the setting is to turn all the way to lock and count the turns made from full soft or full stiff.
Now the little plastic disc should be places over the piston and sits on top of the damper body. I'm pretty sure it's job is to keep the piston from being compressed enough to enable an adjustment change, though changing it requires some pretty serious intent that I highly doubt these could be adjusted "accidentally." The collar/ spring perch from the stock shocks must be transfered to the koni's and the rest of the spring and mount rebuilt and installed in the same manner as the stock setup.
The same weekend I replaced my suspension with the whiteline works kit (along with uiuc240) my friend recieved the Illuminas for his 510. Comparing them, the compression setting of the konis was right around 3/5 on the illumina's. The full soft rebound setting on the koni's was softer than 1/5 on the tokikos and full stiff was stiffer than 5/5. Of course this doesn't account for valving differences (if any) for the differeing applications (240 vs 510).
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 07-31-2003, 04:37 PM   #17
super_hicas
thank you! you guys are great. mine came with instructions but it didnt glow so i didnt read it
Old 07-31-2003, 09:04 PM   #18
super_hicas
wait a minute...does this mean i cant change the settings when they're in the car?
Old 08-01-2003, 01:09 AM   #19
Flybert
Yeah, you can't set them up unless you disassemble them. I set mine to 2/3-3/4 stiff in the back just to be safe that they would be stiff but not too stiff. I have the Pro Kit and I love the ride. It's pretty stiff because I have the front set to full stiff. I might change it up in the near future. I have a feeling that I'm not letting the springs do any of the work but I could be wrong. Anyone have any advice about this?
Old 08-01-2003, 08:14 AM   #20
uiuc240
uiuc240's Avatar
You can change the front whenever you want. To change the back, you have to take the shock/spring out and disassemble. Sorta lame, but that's why you just "set it and forget it!" Seriously, you should be able to just set them at about halfway and you'll be good to go. That should be a good match for your springs.
Eric
Old 08-01-2003, 11:10 AM   #21
super_hicas
i guess thats cool. what setting do they come in? should i change anything? im going to the track end of august and i wanna be prepared. i just ordered ground control coil overs today so im gonna be installing the shocks with my gc's next weekend. any tips for a good drift setup / street setup. something in between. let me know.
Old 08-01-2003, 11:16 AM   #22
uiuc240
uiuc240's Avatar
they come setup at 50% stiff. I would just leave them there. They are only adjustable for rebound. I don't think the GC springs are all that stiff, but they are stiffer than Eibach, that's for sure. You might go 1.5 turns from full soft (75%)...but I dunno. I'd just leave it stock and see how it feels. If it's bouncy, you're too soft (the springs are overpowering the shocks). If it's really slow to come back up, you're too firm.
Eric
Old 08-01-2003, 11:50 AM   #23
super_hicas
sounds like alotta work but ill try that. thanks your awesome. so much support and so much appraisal.
Old 08-05-2003, 12:27 AM   #24
super_hicas
* BUMP * dont want this one to get burried. gonna need it this weekend.
