Old 07-14-2009, 11:03 PM   #1
Japan88
Japan88's Avatar
Japan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to all
White Smoke
A few days ago i turned on my car in the morning, dead cold start... and
alot of White or kinda white greyish started to come out.. it wouldnt stop
for a while... i was thinking it
could have been my seals on my turbo... i bought a brand knew turbo and
it still was smoking white.. so im thinking it could be the rings on my
piston/s.. im not too sure.
any ideas?
Japan88 is offline   Reply With Quote
Old 07-14-2009, 11:09 PM   #2
s13newb
s13newb's Avatar
s13newb is an unknown quantity at this point
Send a message via AIM to s13newb
hEAD gasket ?..? radiator fluid is white wen burning
s13newb is offline   Reply With Quote
Old 07-14-2009, 11:13 PM   #3
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
usually in the moring youll get that due to condensation within the exhaust , but if it persit far after you have warmed up the car most likely your hg blew
S-Nation S13 is offline   Reply With Quote
Old 07-15-2009, 12:05 AM   #4
oats91
oats91's Avatar
oats91 is an unknown quantity at this point
most likly your head gasket
oats91 is offline   Reply With Quote
Old 07-15-2009, 12:05 AM   #5
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
is it smoking at idle or all the time as in when your driving?
SilviaSR20DET is offline   Reply With Quote
Old 07-15-2009, 01:45 AM   #6
teamkunimitsu
teamkunimitsu is an unknown quantity at this point
first check your radiator fluid. does it go low? second check for any signs of oil in coolant system. then put cap back on and start. warm up completely. if just a pure white smoke comes out it will be coolant leaking into cylinders. if it is white with a blue hue to it, it is oil.
if it warms up and no smoke your in the clear, but just to be sure i would pressure test the cooling system with a special pressure tester.
couple of possibilities of coolant. cracked head,cracked block, iacv or tb leaking coolant in to intake, or head gasket which is most likely the cause. Do you have to keep adding coolant into car? if so you got a cross leak.
teamkunimitsu is offline   Reply With Quote
