faulty throttle position sensor?
Just went and did a test with a voltmeter using ohms and its only saying .683-1.3 k ohms with the throttle fully closed when it should be 2 volts. Also when the pedal is at WOT its reading the same ohms where it should be 10ohms? I think the ground is good as its saying 5 kohms which is in spec. im thinking its a bad tps cause im using nistune ecu and its not reading tps idle if anyone is familiar with nistune and my decel is acting up. This is on a ka24de-t.
