Old 07-18-2009, 10:35 PM   #1
s15specR
s15specR's Avatar
Trader Rating: (18)
s15specR is making a name for him/her selfs15specR is making a name for him/her self
Feedback Score: 18 reviews
? What's the ID/OD on S14 Fuel feed and return lines
I need to find the exact ID and OD for the s14 fuel feed and return. I tried measuring is and came up with either 5/16 or 11/32 for the OD. Anyone know the exact size ?
s15specR is offline   Reply With Quote
Old 07-18-2009, 11:43 PM   #2
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
5/16 is the Hose you want to use. have the fun!!!!
Review Thread
bardabe is offline   Reply With Quote
Old 07-18-2009, 11:53 PM   #3
s15specR
s15specR's Avatar
Trader Rating: (18)
Well what I'm doing is using a sleeve and nut to go from hardline to AN fitting so I can plumb an inline pump, fpr and fuel rail with all -an fittings instead of hose clamps.
So this should work fine ?
Earls Plumbing 581905ERL Aluminum Tube Sleeve Tube Size 5/16 Fitting Size 5 2 Per Package Blue Anodized
Old 07-19-2009, 02:47 AM   #4
bardabe
bardabe's Avatar
yeah that shoudl be fine, im sure you already know you are going to need a flaring tool and all that fun stuff.
Review Thread
Old 07-19-2009, 03:44 AM   #5
GSXRJJordan
GSXRJJordan's Avatar
Its been done. *Begin engine bay pimping*
Here's a great shot showing the fuel system without the engine in the way:
-5 Flareless fitting, gives you -5an female on your 5/16" fuel line. Then I've got a -5an -> -6an adapter, giving me the -6an male that I need to mate up to my Aeroquip -6an lines/fittings. The fuel rail has been modded with -6an fittings on either end also (was just talking to Bardabe about this fiasco a couple hours ago lol):
No! They have flare-less fittings now! WOOT! Fuck $100 flare tools I'll only use twice. Flareless fittings don't leak as long as the section you're using is completely straight.
Old 07-19-2009, 04:22 PM   #6
s15specR
s15specR's Avatar
Trader Rating: (18)
All that flake!!!!!
Nice thanks dude, did they not make a 5/16 sleeve with a -6an nut ? I was sure they made one.
Old 07-19-2009, 07:04 PM   #7
GSXRJJordan
All that flake!!!!!
I've never seen one, and my supplier (Hung @ Baker Precision) hadn't either. This is the best solution I think.
Old 07-19-2009, 08:23 PM   #8
s15specR
s15specR's Avatar
Trader Rating: (18)
Is this what you used ?
What pressure can this hold ? Can't seem to find the tech specs on it.
Old 07-19-2009, 08:28 PM   #9
samplesurf
samplesurf's Avatar
samplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to all
they make -5an which is what you must use to fit the stock fuel line, ive done this to mine so i know
you will need the -5an tube sleeves and nuts and then an adapter for the nut to -6an so u can get the hoses and such
heres some links to the nuts and sleeves for the lines
Earl's Performance 581805ERL - Earl's Performance Tube Nuts – SummitRacing.com
Earl's Performance 581905ERL - Earl's Performance Sleeves – SummitRacing.com
samplesurf is offline   Reply With Quote
Old 07-19-2009, 09:21 PM   #10
s15specR
s15specR's Avatar
Trader Rating: (18)
Thats what i originally planned on using, at the end of the hardline there's a little hump in the line, did you cut that off and then flared it ?
Old 07-19-2009, 09:49 PM   #11
MeanS14
MeanS14 is an unknown quantity at this point
Why dont you just use the swagelok fittings to go from hard line to AN? They are so easy!
MeanS14 is offline   Reply With Quote
Old 07-19-2009, 10:01 PM   #12
MeanS14
This was taken from another forum:
OH, and before I forget, if you are using STOCK lines in the chassis, it is NOT 5/16"! It is a Metric 8mm, and both Swagelock and Imperial Eastman make METRIC FITTINGS that will go right on that baby without any modifications whatsoever. The make a whole line of metric to standard adapters as well if you want to 'switch over' to standard stuff near the engine bay for convineience
Hope this helps the OP
Old 07-19-2009, 10:02 PM   #13
s15specR
s15specR's Avatar
Trader Rating: (18)
Can you post a link or some more details please ?
Old 07-19-2009, 10:12 PM   #14
MeanS14
Swagelok compress to AN fittings? - HybridZ
Old 07-20-2009, 01:27 AM   #15
samplesurf
samplesurf's Avatar
yes thats what i did
