Old 07-28-2009, 01:43 PM   #1
TOVI
TOVI's Avatar
TOVI is an unknown quantity at this point
sr20det idle problem
hey guys, my car is giving me some problems. every time im comin to a stop it seems like the idle gets stuck at 1600 rpm. the rpms will go down to like 1300 after a while but ya. does anyone know a solution? would an exhaust leak cause it? please help
TOVI is offline   Reply With Quote
Old 07-28-2009, 02:00 PM   #2
Azimmer
Azimmer's Avatar
Azimmer is an unknown quantity at this point
Send a message via Yahoo to Azimmer
your throttle cable could be getting stuck our the butterfly and your manifold could be getting stuck
LoW BuDgEt DrIfTeR
Azimmer is offline   Reply With Quote
Old 07-29-2009, 11:18 AM   #3
TOVI
TOVI's Avatar
ok, thanks man ill go check it out. i really hope thats the problem
Old 07-29-2009, 03:48 PM   #4
FRoSt415
FRoSt415's Avatar
FRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura about
Send a message via AIM to FRoSt415
can be lots of things. the best way to get an answer is to provide as much information as u know about the car so we can best answer the question. For example what have u tried? What mods are on the car? Engine? Driving conditions piror and after?
What i would do is look for any vaccum hoses that have been ripped, cracked or broken(Check for vac leaks & boost leaks).
Check timing(From this see if there is a misfire). Adjust timing if neccasary
What ur car is doing is that when it is idleing the ECU sends information to richen the car up to compensate for more air coming in. Find out why the car is running lean.
FRoSt415 is offline   Reply With Quote
Old 07-30-2009, 11:15 AM   #5
TOVI
TOVI's Avatar
thanks for the help. i think that my turbo manifold might have a crack in it. well my car has 256 cams, enthalpy tuned ecu, 300z maf, 550cc injectors, megan manifod, garrett gt28rs turbo. i have looked for vacumm leaks before but never found anything. im gona tyr again. hope i can find the problem.
