Old 07-29-2009, 11:33 PM   #1
Menteith
Menteith is an unknown quantity at this point
Weird ECU Codes
So this is what I'm getting:
1 long flash.
2 long flashes
3 short flashes
4 short flashes
5 short flashes
...any help? There isn't a code 3, 4, 5, 10 or 20.
...what do I do???
Menteith is offline   Reply With Quote
Old 07-29-2009, 11:36 PM   #2
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
lol watch it again !!!
S-Nation S13 is offline   Reply With Quote
Old 07-30-2009, 02:55 AM   #3
Menteith
It simply repeats.
Old 07-30-2009, 02:11 PM   #4
Menteith
...anyone?
Old 07-30-2009, 02:23 PM   #5
S-Nation S13
Trader Rating: (92)
um..ok it should be a set of slow flashes then a set of fast flashes lol never came across single digit dtc lol
www.240edge.com <<< here youll find dtc
Old 07-30-2009, 03:56 PM   #6
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
I bet one of those is knock sensor :P
flip3d is offline   Reply With Quote
Old 07-30-2009, 07:35 PM   #7
Menteith
Knock sensor is 34
It's not throwing that code...
...can anyone shoot me a reasonable piece of information...or no?
Old 07-31-2009, 08:23 AM   #8
S-Nation S13
Trader Rating: (92)
Post
what more do you want lol i just gave you the link to your fsm if you dont know how to use it than you dont need to be "trying to fix it" either that or you lazy to read it info i gave was reasonable
Old 08-02-2009, 09:02 PM   #9
AzBrewsky
AzBrewsky's Avatar
AzBrewsky is an unknown quantity at this point
1 long flash.
2 long flashes
3 short flashes
4 short flashes
5 short flashes
...what do I do???
All codes are two digit codes.. Go back and count the codes again.. Count the number of long flashes (this will be the first digit to identify the code), then count the short flashes (this will be the second digit).
Example: LONG LONG LONG SHORT SHORT SHORT SHORT
The example above shows code 34 (three longs and four shorts).
Keep watching, if you have more than one code, then the series will differ to represent multiple codes. Write all the codes down. Once all the codes have been displayed, it will start over..
Now take those codes and refer to your FSM (Factory Service Manual), or post back and we can do the work for you..
AzBrewsky
AzBrewsky is offline   Reply With Quote
Old 08-02-2009, 09:32 PM   #10
Sileighty_85
Sileighty_85's Avatar
AzBrewsky
just to piggy back on this info
Originally Posted by kazuo View Post
- this is general for 89-98 Nissan but most apply to the SR20 motor.
- to set car into diag. mode, with the key in the "ON" position, turn potentometer screw on ECU fully clockwise, then turn it fully counterclockwise. The LED on the ECU will begin to flash.
- first digit = LONG blink; second digit = SHORT blink (ex: 1... 1... 1... 1... then 1-1-1 equals 43 = TPS)
Error Codes Biatch
11 Crank Angle Sensor/Camshaft Position Sensor.
12 Air Flow Meter/Mass Air Flow Sensor.
13 Engine Coolant Temperature Sensor.
14 Vehicle Speed Sensor.
21 Ignition Signal.
22 Fuel Pump.
23 Idle Switch.
24 Throttle Valve Switch.
25 Idle Speed Control Valve.
28 Cooling Fan Circuit.
31 ECM.
32 EGR Function.
33 Heated Oxygen Sensor.
34 Knock Sensor.
35 Exhaust Gas Temperature Sensor.
36 EGR Control-Back Pressure Transducer.
37 Knock Sensor.
38 Right hand bank Closed Loop (B2).
41 Intake Air Temperature Sensor.
42 Fuel Temperature Sensor.
43 Throttle Position Sensor.
45 Injector Leak.
47 Crankshaft Position Sensor.
51 Injector Circuit.
53 Oxygen Sensor.
54 A/T Control.
55 No Malfunction.
63 No. 6 Cylinder Misfire.
64 No. 5 Cylinder Misfire.
65 No. 4 Cylinder Misfire.
66 No. 3 Cylinder Misfire.
67 No. 2 Cylinder Misfire.
68 No. 1 Cylinder Misfire.
71 Random Misfire.
72 TWC Function right hand bank.
73 TWC Function right hand bank.
76 Fuel Injection System Function right hand bank.
77 Rear Heated Oxygen Sensor Circuit.
82 Crankshaft Position Sensor.
84 A/T Diagnosis Communication Line.
85 VTC Solenoid Valve Circuit.
86 Fuel Injection System Function right hand bank.
87 Canister Control Solenoid Valve Circuit.
91 Front Heated Oxygen Sensor Heater Circuit right hand bank.
94 TCC Solenoid Valve.
95 Crankshaft Position Sensor.
98 Engine Coolant Temperature Sensor.
101 Front Heated Oxygen Sensor Heater Circuit right hand bank.
103 Park/Neutral Position Switch Circuit.
105 EGR and EGR Canister Control Solenoid Valve Circuit.
108 Canister Purge Control Valve Circuit.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-05-2010, 05:30 PM   #11
mrmephistopheles
mrmephistopheles's Avatar
Nobody helped this guy...
The flashes are for different modes.
You need to be in mode 3 to pull codes, and then mode 4 resets the ECU. This is only for SOHC models.
Basically, wait till it flashes 3x, then turn the knob back to home.
Originally Posted by PHLIP
Old 04-05-2010, 05:45 PM   #12
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
sohc ecu for sures. if you want to pull codes, turn the diagnostic screw after it has flashed 3 times
WheelsDirty
