Old 09-04-2009, 08:24 PM   #1
proud2b3black
proud2b3black's Avatar
proud2b3black can only hope to improve
Send a message via AIM to proud2b3black
s14 bushing help
i had bought some polyurethane bushing before i looked into what it really took to install them. Now that i know the effort required to install them i wanted to know if there is another solution to installing new bushings. i heard something before about putting in aluminum spacers where the bushings belong.
thanks for the help in advance
proud2b3black is offline   Reply With Quote
Old 09-04-2009, 08:27 PM   #2
Japan88
Japan88's Avatar
Japan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to all
You got the whole kit for all the bushing for your car, or just for the sub-frame bushings?
Japan88 is offline   Reply With Quote
Old 09-05-2009, 09:32 AM   #3
proud2b3black
i have only the rear subframe bushings
Old 09-05-2009, 10:03 AM   #4
kandyflip445
kandyflip445's Avatar
http://www.specialtyz.com/240suspension.htm
Silver platter. lol
My 240 vBgarage
Old 09-05-2009, 10:05 AM   #5
travypoo
travypoo is an unknown quantity at this point
Send a message via MSN to travypoo
you can drop your rear sub frame and do solid alumn bushings like this
or you can buy slotted sub frame collars and just lower the sub frame and slide them in on the bottom and top of the stock rubber ones. the most simple way thats for sure
travypoo is offline   Reply With Quote
Old 09-05-2009, 01:07 PM   #6
Japan88
Japan88's Avatar
I secound that. or just throw in the bushings you have now. Lazyness wont get you no where. Get on it.
Old 09-05-2009, 04:57 PM   #7
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Sorry but solids are the way to go on an S14, there is nothing that will match them.
Bigsyke is offline   Reply With Quote
Old 09-05-2009, 05:36 PM   #8
GSXRJJordan
GSXRJJordan's Avatar
Agreed solid subframe bushings (I bought PBM subframe risers to get some geometry correction) and poly diff bushings are the best of both worlds. Solid diff bushings make noise/rattle a bit.
Old 09-07-2009, 12:19 AM   #9
proud2b3black
thanks appreciate the help and advice
bushings, suspension
