Old 02-21-2002, 01:38 PM   #1
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
i know all these stands for somthing, i'm gettin rims so i try to know what all these means.
the p195
the 60R
the 15 (is it my rim size?)
and the 87t
only on one tire it says 87H, which i assume, it's a new tire, since it's different from the 3 others...
240meowth is offline   Reply With Quote
Old 02-21-2002, 01:42 PM   #2
twofortysx
twofortysx is an unknown quantity at this point
195 is the width of the tire in millimeters.
60 is the height by percentage in millimeters of the width.
15 is the size of the wheel
87t is the rating of your tire. I forget the rating specs but I'm sure they are out there. The t is generally a speed rating. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
EDIT: Changed the measurments, added tihs URL:
<a href="http://www.toyo.com/tires/index_frame.html" target='_blank'>http://www.toyo.com/tires/index_frame.html</a> &nbsp;
Go there and click &quot;Tire Basics&quot;
(Edited by twofortysx at 1:49 pm on Feb. 21, 2002)
twofortysx is offline   Reply With Quote
Old 02-21-2002, 01:52 PM   #3
luey02
luey02 is an unknown quantity at this point
#### twoforty, I'm sure you know what you're talkin about but you need to read your post over.. &nbsp;
195 is the width in Millimeter
60 percentage of 195 is tire height, or thickness..
15 is size of the rim it goes onto
i only know z is the highest speed rating, &gt;120mph
luey02 is offline   Reply With Quote
Old 02-21-2002, 01:55 PM   #4
Guest
Posts: n/a
T is rated to 118mph, S is 112, H is 130, V is 149, Z is 149 plus
Old 02-21-2002, 02:07 PM   #5
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
to clarify a little
60 is the aspect ratio of the sidewall to the width. &nbsp;Your tire is 195mm or 7.7 inches wide. &nbsp;60% of 195 is 117...so your sidewalls are 117mm or 4.6 in. tall.
The R in the R15 stands for radial.
LanceS13 is offline   Reply With Quote
Old 02-21-2002, 02:16 PM   #6
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
thank you lance for the correction!! &nbsp;
burgy240 is offline   Reply With Quote
Old 02-21-2002, 02:35 PM   #7
LanceS13
AutoX Junkie
not really a correction, just trying to make it easier to understand:)
Old 02-21-2002, 02:49 PM   #8
twofortysx
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from luey02 on 12:52 pm on Feb. 21, 2002
</td></tr></table><span id='postcolor'>
Thanks for catching that - I changed the errors.
Old 02-21-2002, 09:14 PM   #9
240meowth
if my tire is 7.7&quot; wide, what does that say about my rims? &nbsp;r my rims around that? 'cause i recall 7.5 is quite big
Old 02-21-2002, 09:28 PM   #10
Guest
Posts: n/a
no. &nbsp;If you have factory rims, they are probably 6.5's
Old 02-22-2002, 01:16 AM   #11
240meowth
now i'm all confused... wha dose rim width has to do w/ tire width?
Old 02-22-2002, 05:01 AM   #12
DuffMan
DuffMan's Avatar
It's natural for tires to be wider than the rim. The rim should be at the very least 70% of the tire width, though the rim should preferably be in the 80%-90% range.
