Old 09-07-2009, 05:29 PM   #1
AzBrewsky
AzBrewsky's Avatar
AzBrewsky is an unknown quantity at this point
What is this??
What is this sensor, and does it require a gasket? It appears as I am getting an oil leak from it..
AzBrewsky is offline   Reply With Quote
Old 09-07-2009, 05:32 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
Oil Pressure.
When mine developed a leak there, it ended up being a cracked housing.
There is no gasket, just the threads for the sensor to screw in.
Old 09-07-2009, 08:16 PM   #3
projectRDM
projectRDM's Avatar
Discard and plug. A new one will leak within a year anyway, they all do.
FORMERLY R240NA
Old 09-08-2009, 02:32 AM   #4
cotbu
cotbu's Avatar
It's a "T" to keep the oil pressure sensor. That's what you have circled.
The sensor is on the end and the T is probably used to feed a gauge or turbo.
If you are leaking from the sensor...
If you are leaking from another part of the T, you'll figure it out eventually.
Old 09-08-2009, 07:16 AM   #5
AzBrewsky
AzBrewsky's Avatar
If I were to plug it, wouldn't that send a CEL?
Old 09-08-2009, 07:36 AM   #6
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
no
msssssggggggg
clark is offline   Reply With Quote
Old 09-08-2009, 08:03 AM   #7
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
Originally Posted by clark View Post
no
msssssggggggg
confirmed...hell...ud think ud get a CEL for the leaking one u have now...
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 09-08-2009, 08:22 AM   #8
projectRDM
projectRDM's Avatar
Exactly. Why would the emissions control system care if you're leaking oil?
CEL = check engine light. Emissions related items only.
FORMERLY R240NA
Old 09-08-2009, 08:30 AM   #9
Shift-240
Shift-240 is an unknown quantity at this point
mine cracked then broke off in the block. it was hell getting the broken peice out.
Shift-240 is offline   Reply With Quote
Old 09-08-2009, 10:58 AM   #10
projectRDM
projectRDM's Avatar
Weird that it broke off in the block seeing as how it's threaded into the oil filter bracket and not the block. And since the bracket is easily removed it can also be easily replaced.
FORMERLY R240NA
Old 09-08-2009, 12:32 PM   #11
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
so this ok to hook up a defi gauge to it or is it better off to get the adaptor for the filter.
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 09-08-2009, 12:39 PM   #12
zenki.life
zenki.life's Avatar
zenki.life is an unknown quantity at this point
Send a message via AIM to zenki.life
the latter. mmmhmmm
Originally Posted by super240s14 View Post
man you all are ass holes...... and that is rude to talk like that on zilvia im reporting all you...... ZILVIA ADMINISTRATION PLEASE BANNED ALL THREE OF THESE DUDES
^^another person learns the perils of "stupid posting" on zilvia, too bad none will care.
zenki.life is offline   Reply With Quote
Old 09-08-2009, 12:39 PM   #13
ShereKhan
ShereKhan's Avatar
ShereKhan is an unknown quantity at this point
Ya just plug it for now Brew. If you feel like replacing it just do it later.
If you don't like that route then replace it with a new one, its an old motor so that will happen to ya
ShereKhan is offline   Reply With Quote
Old 09-08-2009, 12:43 PM   #14
projectRDM
projectRDM's Avatar
What? English, type it.
You can't use the OE sender to do anything. You can however install any aftermarket sender in it's place as long as the fitting is the same.
FORMERLY R240NA
Old 09-08-2009, 01:19 PM   #15
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
1/8 Ntp i think... correct me if im wrong...
PSN
Old 09-08-2009, 01:25 PM   #16
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
These can be removed and plugged?
Neat, another thing I can get rid of.
Old 09-08-2009, 01:46 PM   #17
projectRDM
projectRDM's Avatar
Wow mang, where have you been?
Yes, delete it. Your alternator will appreciate the lack of oil pouring into it.
FORMERLY R240NA
