FS: S14 Koni/GC setup
My loss is your gain. Everything (except when noted) is brand new, never even mounted on a car.
Front: -S14 Koni yellows already inserted into stock tubes meticulously cleaned up and repainted with flat black. -7" 400# 2.5ID Hyperco springs -Ebay special camber plates -TechnoToyTuning upper hats -Ground Control bump stops, already trimmed -Roller bearings on the bottom of the springs -Most of the miscellaneous hardware, just need another small sleeve Rear: -S14 Koni yellows rebuilt and revalved to handle 300# at the minimum setting (tried to convert to externally adjustable, but Koni does not have a hollow rod long enough at the time) -7" 300# 2.5ID Eibach racing springs (used) -Ground control bump stops -TechnoToyTuning top hats -You can either use a stock top mounting solution or use aftermarket such as the Tein top mounts Misc: -a **** ton of random sleeves, washers -a few more TechnoToyTuning upper hats -a pair or two of used 5" Eibach racing springs, I don't remember off the top of my head the specifics, probably not very helpful for 240 setups. Located in Atlanta/Gwinnett. At this time I am entertaining local offers (packing and shipping will be a pain and expensive) and am not parting out. Asking for $900 firm. I spent at least $1200-1300 collecting everything, the small stuff really adds up. If you are not local and are interested, email me maybe we can work something out. PLEASE EMAIL [email protected] that is the easiest way to reach me I don't check forums often. ![]() ![]() Last edited by yudalicious; 11-02-2009 at 11:12 PM.. |
#5 | |
Edit: Missed the first question. Yes you'd need a tiny (iirc ~1mm) sleeve in the front to perfectly center the 2 washers... I was just going to use some o-rings. In the back as mentioned you need to figure out your own mounting solution, pretty easy to do with either stock mounts or an aftermarket pillowball unit like Tein. |
I hate to sell them but the 240 is really old and I gotta put money towards a more reliable DD... They won't dump your car but they should be great.....
#10 | |
460
