Old 08-27-2003, 10:30 AM   #1
RedlineRacer
RedlineRacer is an unknown quantity at this point
Send a message via ICQ to RedlineRacer Send a message via AIM to RedlineRacer
Clutch Fluid
I've been going through clutch fluid pretty fast. Two weeks ago I changed my clutch and then I filled up my clutch cylinder to the top and I check it the other day and it was almost empty. This is not the first time its done this.
Also, I thought it might be a leak in my lines. But I looked at the concrete where I park my car at, and there aren't any spots of fluid.
RedlineRacer is offline   Reply With Quote
Old 08-27-2003, 10:31 AM   #2
Dousan_PG
Dousan_PG's Avatar
check the lines (hard and soft). check your cylinders (master and slave)
Aaron
Pink GodziRa
Old 08-27-2003, 10:33 AM   #3
RedlineRacer
Damn Dousan, quick response. Where is the slave located at? Should I be looking for cracks in the lines?
Old 08-27-2003, 10:44 AM   #4
the head
the head's Avatar
Location: in a dark room mastering the art of typing with one hand
the head is making a name for him/her selfthe head is making a name for him/her self
look for cracks and wet areas around and on the lines slave cyl is bolted to the side of the trans just follow the line down from the master cyl
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
