Old 10-06-2009, 08:41 PM   #1
SkyHighPsi
SkyHighPsi is an unknown quantity at this point
How to hook up JDM signal lights?
So how would you hook up JDM signal lights onto a usdm car? I'm trying to make soldering my last resort.
btw only tutorial I found was this http://zilvia.net/f/tech-talk/114133...ignal-mod.html but I want to make them normal.
SkyHighPsi is offline   Reply With Quote
Old 10-06-2009, 08:52 PM   #2
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
its just power and ground man. Find the power wire and find the ground cut and splice use shrink wrap or krimp it using a splice tube. when your all done use electricall tape and walaa done.
s13 @ fullboost is offline   Reply With Quote
Old 10-06-2009, 09:16 PM   #3
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
The front indicators? Dude, they're plug and play.
Old 10-06-2009, 09:55 PM   #4
SkyHighPsi
No the JDM plugs don't fit.
Eh, never done that before. Are there any tutorials I can look at?
Old 10-06-2009, 10:06 PM   #5
ILoveMyRHS13
Trader Rating: (25)
Are you talking about the front marker lights on the fenders, or the indicators on the front bumper?
Old 10-06-2009, 10:06 PM   #6
slow40sx
slow40sx's Avatar
slow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud of
Send a message via AIM to slow40sx
do you mean the kouki position lights?
JDM zenki and chuki plug right in
slow40sx is offline   Reply With Quote
Old 10-06-2009, 10:17 PM   #7
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Feedback Score: 79 reviews
if there the bumper lights (half amber ones) & without harness then you have to.........
get another bulb with pigtail from another usdm bumper lights at the junkjard or where ever?
then you have to get one bulb with pigtail cut the connector & splice it into the green wire (indicator)& black wire(ground)
then with the other bulb with pigtail just plug it into the connector & that will be your stationary
then just put the bulbs into the light housing & im pretty sure that will do the trick....
jdm2191 is offline   Reply With Quote
Old 10-06-2009, 11:12 PM   #8
s13 @ fullboost
well ether way this is in the wrong section good luck with your Hella Jdm turn signals
Old 10-07-2009, 10:27 AM   #9
ixfxi
Guest
Posts: n/a
you need wire
maybe a connector
or two
Old 10-07-2009, 10:59 AM   #10
Om1kron
Om1kron's Avatar
it requires soldering and some creativeness.
Wayne Edwards
https://om1kron.blogspot.com
Old 10-07-2009, 11:40 AM   #11
Somnambulist
Somnambulist's Avatar
Somnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfection
Send a message via AIM to Somnambulist
Wood and nails worked well for me.
Somnambulist is offline   Reply With Quote
Old 10-07-2009, 11:52 AM   #12
kensreliableb18b
kensreliableb18b's Avatar
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
kensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nice
ghetto, i use aluminum foil.
My car is looking for a new home. Buy my car today!
kensreliableb18b is offline   Reply With Quote
Old 10-07-2009, 01:41 PM   #13
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
y would soldering be ur last resort?
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 10-07-2009, 03:23 PM   #14
slow40sx
slow40sx's Avatar
can you post pictures of the signals, there are 3 possible signals you speak of, actually 4 if you kave a kouki 180 bumper and i don't even know if your talking about an S13 i'm guessing you are but i don't know
Old 10-07-2009, 03:30 PM   #15
ixfxi
Guest
Posts: n/a
now, there are actually only 3 types of turn signals
89-90 fastback (also for silvia)
91-94
and
96-98 180sx (only the lowers are turns, the uppers are parking lights)
all are the same (in terms of wiring) except for the 96-98.
therefor, he must be talking about 96-98 180sx.
which still require wire, and possibly a connector.
or two.
Old 10-07-2009, 05:33 PM   #16
kensreliableb18b
96-98 you can either pick up the sockets from nissan for the signals or you can just one off the connectors--just go to radioshack and pick up the connectors.
Old 10-07-2009, 08:41 PM   #17
SkyHighPsi
Sorry I didn't be specific enough. I'm talking about the kouki s14 turn signals like this one
FS: JDM Kouki S14 turn signals!! CHEAP: Exterior (for sale): Nissan Forums / Infiniti Forums - NICOclub
I was hoping if anyone has done a quick tutorial on how to hook these up and if someone can post a link that would be great
Old 10-08-2009, 01:04 AM   #18
projectRDM
projectRDM's Avatar
What do you mean by 'how'? How do you want to hook them up? There's two bulbs, you can wire them in any number of combinations but no one on here knows what it is you want to do, we don't read minds.
If you're just asking how to connect wiring, you need to begin somewhere else. Like 5th grade.
FORMERLY R240NA
