Old 09-02-2003, 12:12 AM   #1
Break Beats
Break Beats is an unknown quantity at this point
s14 S14 Front Strut Bolts.
Hi, I need all four of the front strut nuts and bolts. The ones that connect the strut to the spindle. I need them ASAP! Thank You!
Contact me:
E-Mail - [email protected]
Break Beats is offline   Reply With Quote
Old 09-03-2003, 04:13 PM   #2
yenpit
yenpit is an unknown quantity at this point
Dealer new....can't be that much $$ ?? If you can't find OEM bolts, try Ingall's front camber kit #I-81250.....it takes the place of the stock bolts and gets you camber adjustment if you've lowered the car (you should still be able to use it even if not lowered). If desperate, go to a good hardware store, be sure your measurements are correct, and get aircraft quality, hardened bolts WITH a long enough shank (threads do not go all the way to the bolt head). Hope that helps!
'98 240SX 5spd[br]http://www.speedwisemotorsports.com
yenpit is offline   Reply With Quote
