Old 10-25-2009, 11:38 AM   #1
roel03
roel03 is making a name for him/her selfroel03 is making a name for him/her self
Using NA 300ZX VLSD on an S14
Can I just insert my 6-bolt open diff output shafts into the 300ZX unit or does it have to be 240sx 6-bolt ABS VLSD output shafts that you put in?
roel03 is offline   Reply With Quote
Old 10-25-2009, 07:53 PM   #2
roel03
Anyone know?
Old 10-25-2009, 07:56 PM   #3
Propaganda
Propaganda's Avatar
Propaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enough
pretty sure you need VLSD output shafts
Propaganda is offline   Reply With Quote
Old 10-25-2009, 08:04 PM   #4
articdragon192
articdragon192's Avatar
You need Z32 5 bolt output shafts to run a Z32 unit. Anything other than the Z32 output shafts won't work.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 10-25-2009, 08:34 PM   #5
roel03
Thats not right. You can swap the 240 output shafts into the unit to avoid switching axles, just making sure if it has to be VLSD shafts or open.
Old 10-25-2009, 08:36 PM   #6
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
Open diff output shafts are too short and it will be open diff unless you use vlsd output shafts
WangonwWarrior is offline   Reply With Quote
Old 10-25-2009, 08:41 PM   #7
roel03
Thank you, I just wanted to make sure. I already have the 5 bolt output shafts, just need the J30 5 bolt axles. Anyone know where to score some?
