Old 10-28-2009, 07:21 AM   #1
isimon91
isimon91's Avatar
isimon91 is an unknown quantity at this point
Send a message via AIM to isimon91
T3/T4 Garrett Turbo, Manifold, WG, Downpipe
Shipping: At buyer's expense
-T3/T4 .57trim 60comp Garrett Turbo ($350)
Minimal shaft play, ran fine and pulled strong.
-Peakboost Top Mount Manifold w/ 38mm Tial External Wastegate for SR20 ($600)
This is a top mount manifold, with the Tial wastegate welded onto the manifold.
-Peakboost 3" Stainless Downpipe ($250)
3" peakboost top mount downpipe for a top mount turbo (used in T3/T4 setup).
-SR20DET 370cc Stock Injectors w/ fuel rail and FPR ($200)
Worked well before removed, low mileage. I upgraded to larger injectors.
-Greddy BOV ($75)
Worked fine when it was on the car
-Greddy SR20DET Intake Manifold ($400)
-SR20 Nismo Motor mounts ($100)
-Stock SR20DET radiator w/ Nissan Electric fans ($135)
Never overheated, ran fine for two years on my SR swap.
-VMount Intercooler setup.. pm for pricing
Comes with C&R import racing radiator w/ single electric fans, custom radiator hoses (includes extra lower hose), modified greddy coolant surge/fill tank painted sparkly black w/ new rad cap, modified Greddy M spec intercooler core (painted black), steel hot pipe w/ nipple for wastegate hose, aluminum greddy flanged cold pipe
-OEM S13 Shortblock ($150)
Has bad rings, needs a honing, perfect for a rebuild project.
-OEM SR20 Flywheel ($50)
Needs a light resurfacing, comes with all flywheel bolts.
-OEM S13 Suspension($150)
OEM Springs/Struts, no issues, drove fine.
-OEM S13 FLCAs ($30)
OEM S13 Front lower control arms, good condition, ball joints are slightly worn and should be replaced.
-OEM S13 RUCAs ($40)
No issues, selling b/c I needed adjustable rear camber.
-OEM SR20 O2 Sensor(Make an offer!!)
-OEM SR20 Transmission Gasket (Make an offer!!)
-OEM SR20 Pulleys ($80)
Will include pulley belts for $20
-OEM SR20 Bell Housing Bolts (Make an offer!!)
Bolts that connect the SR transmission to the block
-Greddy FMIC Kit for T3 Turbo ($200)
No issues, FMIC needs slight repair, bent mounting bracket. Easy fix with some JB weld.
-Aluminum racing radiator with 2inch core ($150)
No issues, fits S13 engine bay perfectly. Needs custom mounting brackets.
-OEM S13 Tie Rods
Never had a problem, came on a steering rack that I swapped onto my car.
If you have any questions, feel free to email me at [email protected] or PM me.
Pictures:
If you're interested, the best way to contact me is by email, @ [email protected]
1993 S14 SR Powered Hatch: Sold
1989 S13 SR Powered Coupe: Money pit
isimon91 is offline
Old 10-31-2009, 04:04 PM   #2
isimon91
isimon91's Avatar
bumpppppppppp
isimon91 is offline
Old 11-19-2009, 04:47 PM   #3
isimon91
isimon91's Avatar
bump, new items and prices added
isimon91 is offline
Old 11-19-2009, 04:56 PM   #4
240sxScores
240sxScores's Avatar
240sxScores is making a name for him/her self240sxScores is making a name for him/her self
Send a message via AIM to 240sxScores
This for SR or KA. Theres no prices listed either. And whats up with the waste gate on the manifold so far away?
240sxScores is offline
Old 11-19-2009, 07:37 PM   #5
SMM
Trader Rating: (26)
SMM is an unknown quantity at this point
Feedback Score: 26 reviews
I dont see prices...
SMM is offline
Old 11-19-2009, 08:42 PM   #6
midnight_rex
midnight_rex is an unknown quantity at this point
prices would be nice
midnight_rex is offline
Old 11-27-2009, 11:24 AM   #7
isimon91
isimon91's Avatar
bump bump, prices added, more items to come in the next couple weeks.
isimon91 is offline
Old 11-27-2009, 07:54 PM   #8
deolio
deolio's Avatar
do you know which model the bov is?
deolio is offline
Old 11-30-2009, 12:40 AM   #9
isimon91
isimon91's Avatar
Not sure, came on the fmic piping I bought. I'll find out and PM you with the model.
The wg was relocated- the dumptube used to scrape because the car was low, it would go out just below the frame rail.. its now near the strut tower with no issues.
isimon91 is offline
Old 11-30-2009, 07:54 AM   #10
Godchsr
Godchsr is an unknown quantity at this point
New to turbos, sorry for the noob question... what's the efficiency range of the Garrett, 400-500 whp?? or lower?
I'll PM you too.
Godchsr is offline
Old 12-03-2009, 08:58 PM   #11
rotas13
rotas13's Avatar
rotas13 is an unknown quantity at this point
any chance your selling the oil cooler? Pm me if possible!
rotas13 is offline
