Old 11-16-2009, 09:07 PM   #1
kroos268
kroos268 is an unknown quantity at this point
Send a message via AIM to kroos268
Is your MAF good? The blow test
I know my z32 used MAF is responsive, because the signal wire generates 1V when I blow through the MAF.
Is it possible it is still bad? I am getting terrible idle and don't find any leaks.
kroos268 is offline   Reply With Quote
Old 11-17-2009, 07:26 AM   #2
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
^ I don't remember what mine read but I wouldn't think its the culprit if it is responding to air flow. Have you recently messed with your coolant system? If an air pocket is created in the IACV an SR20, which I'm assuming this is, will idle terribly. IIRC the motor should idle without the MAFS hooked up but can't be revved above 2k RPM.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 11-17-2009, 12:49 PM   #3
FRoSt415
FRoSt415's Avatar
FRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura about
Send a message via AIM to FRoSt415
clean out the sensor inside the maf if its dirty it wont get u accurate readings. Use mass air flow sensor cleaner when doing so
FRoSt415 is offline   Reply With Quote
